    worldclock - nobody made this, so I did.
    46 Posts 14 Posters 33.3k Views 14 Watching
      cookblook
      very nice module. Is it possible to have the clocks horizontal instead of vertical?
        A Former User @cookblook
        @cookblook
        You can redefine CSS of .worldclockand.worldclock .world to arrange horizontally with flex things of CSS3.
          cookblook @Guest
          @sean like display: flex;? tried that but it didn’t work
            @cookblook
            This will work, add this into your css/custom.css
            .worldtime {
              display:flex;
              flex-direction:row;
            .world{
              width:200px;
              cookblook
              @sean Thanks!! That worked :-)
              • BKeyportB Offline
                BKeyport Module Developer
                Ulrich/Sean -
                I’ve got a bug - supposedly it’s supposed to allow override of the time format per clock. I’m trying to get a 24 hour clock only on the UTC clock. “LT” is “hh:mm A” here…
                Thanks!
                 module: "worldclock",
                 timeFormat: "LT", style: "left",
                 offsetTimezone: null,
                 clocks: [
                 title: "Local",
                 timezone: "America/Los_Angeles",
                 title: "UTC",
                 timezone: "UTC",
                 timeFormat: "HH:mm",
                Thanks!
                • L Offline
                  Lagmin
                  • BKeyportB Offline
                    I solved this. My fork is http://www.github.com/bkeyport/MMM-Worldclock if you’d like to use it. It’ll be fully supported, and I don’t plan to merge back into the original.
                      alanodoug
                      Hey guys,
                      is it possible to change the flag-icon? Because the flag i want to use doesnt exist.
                      Maybe i can use a image and put it in the folder?
                      Thx
                      • BKeyportB Offline
                        No. The flags are hardcoded. I’m trying to figure out how it works, because I want to use a flag for UTC, which don’t have one either.
                        I’m about halfway there. I’ve figured out how to do everything but get the replacement flag into the right spot. It’ll display, but it’s not showing up at the right spot. Still crunching, will look more when time permits. . :|
                        • BKeyportB Offline
                          @alanodoug said in worldclock - nobody made this, so I did.:
                          Hey guys,
                          I’ve added the functionality to MMM-Worldclock. The supported version™
                          It’s not perfect, but it’s there.
                          Is created by:
                          			module: "MMM-Worldclock",
                          				style: "right",
                          				clocks: [
                          						title: "Local",
                          						altflag: "washington.png",
                          						timeFormat: "hh:mm:ss a",
                          						title: "ET",
                          						timezone: "America/New_York",
                          						flag: "us",
                          						timeFormat: "hha MM/DD",
                          						title: "CT",
                          						timezone: "America/Chicago",
                          						flag: "us",
                          						title: "MT",
                          						timezone: "America/Boise",
                          						flag: "us",
                          						title: "AK",
                          						timezone: "America/Anchorage",
                          						flag: "us",
                          						title: "HI",
                          						timezone: "Pacific/Honolulu",
                          						flag: "us",
                          						title: "UTC",
                          						timezone: "UTC",
                          						timeFormat: "HH:mm MM/DD",
                          						altflag: "world.jpg"
                          the module is located at http://www.github.com/BKeyport/MMM-Worldclock
                          Cheers!
                          I really need someone to help me with the CSS buildout. I’m not understanding how to get the icons down to the same size as the normal flags, and other little ticky stuff.
                          What I added was “altflag” in the code, and based it off of what Sean did originally.
                          The combo of JS and CSS is maddening me.
                            alanodoug
                            Oh cool, that looks good.
                            is it not possible to create a custom css. Because in the worldclock.js is the link to the flags
                            loadCSS: function() {
                                var css = [
                                    href: 'https://cdnjs.cloudflare.com/ajax/libs/flag-icon-css/2.8.0/css/flag-icon.min.css'
                            and there are a lot of flags, wich I can change it maybe?
                            But I cant find the svg.
                            Maybe someone can help?
                            Thanks a lot.
                            • BKeyportB Offline
                              Those SVGs are for the built in flags. I figured it would be “download and place the file in the module directory” for the custom flags… Like I have “world.jpg” and “washington.png” (or is it the other way).
                              Just make sure the flag image is square, and use “altflag” rather than “flag” with the filename of the image file, and it’ll pick it up.
                              (the requirements are hopefully temporary for the alternate flag image, I’m working on learning CSS in my spare time, and how to fix the image insert later)
                              • 3 / 3
