    MMM-GoogleDriveSlideShow
    37 Posts 10 Posters 20.9k Views 11 Watching
    • E
      emrah_asl @sdetweil
      @sdetweil Sure. I will this tomorrow, I’m just testing the changes.
      this time, client always sending request to google drive.
      I am not sure that my tricks are correct way.
        clegallic @chen31
        Hi @chen31
        The module is designed to adapt the display size of the image based on your maxWidth and maxHeight configuration (see there)
        If it does not works, perhaps the display is cut by another module above on your MagicMirror ?
        If not, can you share a screenshot to let me understand the problem.
        Regards,
        Charles
          clegallic @emrah_asl
          @emrah_asl
          @sdetweil is right, feel free to create a pull request.
          If you want to force cache reloading, you can also delete the .cache file in the module folder.
          The default cache lifetime is 24 hours (refreshDriveDelayInSeconds configuration parameter).
          Regards,
          Charles
            chen31 @clegallic
            @clegallic said in MMM-GoogleDriveSlideShow:
            Hi @chen31
            Regards,
            Charles
            Hi Charles,
            I went through this one more time and these are pictures that are portait.
            I saw that it’s in your TO DO list.
            Thank you.
            • E
              emrah_asl @clegallic
              @clegallic I think there is an issue here,
              I deleted one image 2 days ago, from google drive also I deleted content from cache file.
              But I see, it 'is still showing.
              When I add new ımage, it automatically detecting in 10 seconds to show this, but when I delete this it is not working same style.
              Can we optimize it at least one hour to refresh caches ?
              • A
                amanzimdwini @clegallic
                @clegallic - I am on a Rasp3A, but fully patched (npm 6.14.8, node 10.23.0, nodejs 10.23.0).
                As su, I fail npm run token:generate - with a
                Type Error: cannot read property '0' of undefined...
                (there is more). Upon inspection MY credentials.json file starts like
                {"web":{"client_id
                while your example begins
                {"installed":{"client_id
                (the rest looks similar to your example) Any idea what I did wrong? If I just replace my “web” with “installed”, I still fail.
                Thanks,
                K
                • W
                  Wil
                  I was trying to install this module but got an error at the npm run token:generate:
                  pi@raspberrypi:~/MagicMirror/modules/MMM-googleDriveSlideShow $ npm run token:generate
                  > mmm-googledriveslideshow@0.0.1 token:generate /home/pi/MagicMirror/modules/MMM-googleDriveSlideShow
                  > node generate-auth-token.js
                  /home/pi/MagicMirror/modules/MMM-googleDriveSlideShow/generate-auth-token.js:33
                    const OAuth2Client = new google.auth.OAuth2(client_id, client_secret, redirect_uris[0]);
                  TypeError: Cannot read property '0' of undefined
                      at fs.readFile (/home/pi/MagicMirror/modules/MMM-googleDriveSlideShow/generate-auth-token.js:33:86)
                      at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! mmm-googledriveslideshow@0.0.1 token:generate: `node generate-auth-token.js`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the mmm-googledriveslideshow@0.0.1 token:generate script.
                  npm ERR!     /home/pi/.npm/_logs/2021-01-19T20_03_53_720Z-debug.log
                  and here is the associated log file:
                  1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'run', 'token:generate' ]
                  2 info using npm@6.14.10
                  3 info using node@v10.23.1
                  4 verbose run-script [ 'pretoken:generate', 'token:generate', 'posttoken:generate' ]
                  5 info lifecycle mmm-googledriveslideshow@0.0.1~pretoken:generate: mmm-googledriveslideshow@0.0.1
                  6 info lifecycle mmm-googledriveslideshow@0.0.1~token:generate: mmm-googledriveslideshow@0.0.1
                  7 verbose lifecycle mmm-googledriveslideshow@0.0.1~token:generate: unsafe-perm in lifecycle true
                  8 verbose lifecycle mmm-googledriveslideshow@0.0.1~token:generate: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/modules/MMM-googleDriveSlideShow/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                  9 verbose lifecycle mmm-googledriveslideshow@0.0.1~token:generate: CWD: /home/pi/MagicMirror/modules/MMM-googleDriveSlideShow
                  10 silly lifecycle mmm-googledriveslideshow@0.0.1~token:generate: Args: [ '-c', 'node generate-auth-token.js' ]
                  11 silly lifecycle mmm-googledriveslideshow@0.0.1~token:generate: Returned: code: 1  signal: null
                  12 info lifecycle mmm-googledriveslideshow@0.0.1~token:generate: Failed to exec token:generate script
                  13 verbose stack Error: mmm-googledriveslideshow@0.0.1 token:generate: `node generate-auth-token.js`
                  13 verbose stack Exit status 1
                  13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                  13 verbose stack     at EventEmitter.emit (events.js:198:13)
                  13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                  13 verbose stack     at ChildProcess.emit (events.js:198:13)
                  13 verbose stack     at maybeClose (internal/child_process.js:982:16)
                  13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                  14 verbose pkgid mmm-googledriveslideshow@0.0.1
                  15 verbose cwd /home/pi/MagicMirror/modules/MMM-googleDriveSlideShow
                  16 verbose Linux 5.4.83-v7+
                  17 verbose argv "/usr/bin/node" "/usr/bin/npm" "run" "token:generate"
                  18 verbose node v10.23.1
                  19 verbose npm  v6.14.10
                  20 error code ELIFECYCLE
                  21 error errno 1
                  22 error mmm-googledriveslideshow@0.0.1 token:generate: `node generate-auth-token.js`
                  22 error Exit status 1
                  23 error Failed at the mmm-googledriveslideshow@0.0.1 token:generate script.
                  23 error This is probably not a problem with npm. There is likely additional logging output above.
                  24 verbose exit [ 1, true ]
                  Anyone have an idea how to solve this?
                  • W
                    Wil
                    Ok I find the problem, my credential file was not good.
                    I made a new one and the npm run token:generate worked.
                    I write the config as mentioned, and start MM but no pictures appear.
                    Is it long to load pictures?
                      clegallic
                      Hi Will,
                      I’m glad to see that you have solved your token problem.
                      The time it takes to load picture depends on the number of pictures you have. Note that only pictures meta-data are loaded at start. The picture binaries are loaded on demand when the slideshow starts.
                      • if rootFolderId is not set, the module will retrieve the 100 first pictures found (maxResults)
                      • if rootFolderId is set, the module will go through the 10 first folders (maxFolders) it founds. If you have a large amount of pictures, or if you specified a large value for maxFolders, it can take more times.
                      If nothing is loaded or displayed, feel free to set debug to true and send me the logs.
                      Regards,
                      Charles
                      • W
                        Wil
                        Hi clegallic,
                        To test I only put 2 pictures, so it should be quite fast.
                        Sorry for my ignoring but after setting debug: true in the config file, where do i see/find the logs?
                          clegallic
                          If your MM is deployed on a Raspberry Pi, you should find the logs in the /home/pi/.pm2 folder (pm2.log, logs/mm-error-0.log or logs/mm-out-0.log).
                          Regards,
                          Charles
                          • H
                            handelni @Wil
                            @wil said in MMM-GoogleDriveSlideShow:
                            my
                            Could you tell me how u did fix this issue? -> the read property ‘0’ of undefined?
                            I did already change from web to installed
                            • A
                              AFSC
                              hello, I have two questions if you can help me
                              1 is it possible to change the photo manually using a touch screen?
                              2 it is possible to play videos
                                sdetweil @AFSC
                                @afsc 1. looks like you could do it, IF you used something like MMM-Buttons to add touchable buttons and send the notification u configure… altho it looks like auto and manual are exclusive… so, once u pick manual then its manual all the time. see the README
                                1. don’t think so, not with this module, which displays pictures… it takes a different technology to play videos vs display pictures
                                • A
                                  AFSC @sdetweil
                                  @sdetweil my idea was to be able to step back and move forward in the photos
                                  I didn’t want it to stop being automatic
                                    sdetweil @AFSC
                                    @afsc I don’t KNOW, not my module, just reading the doc…
