    The screen starts to flickering every 10 seconds every time i use this modules
    1 Posts 1 Posters 483 Views 1 Watching
    • N Offline
      NicolasJorquera
      [config.js es bellow]
      Im working with this 3rd party modules: MMM-Spotify, MMM-GmailFeed, MMM-Screencast, MMM-MotionDetector. I must say that i also configure the auto start magic mirror.
      Ive tried to put those modules together like three times and every time ive got the same error, my screen starts to blink every 10 seconds approximately (but once i have restarted the raspberry pi 4).
      At first i thought that it might be the screen but then ive tried with others and stays the same.
      The last time ive tried to go and install just one module at a time and wait for it to fail (this time I got to install and use in the config file this modules: MMM-Spotify, MMM-MotionDetector (i must say that i also do not install the auto starting magic mirror thing)), and in that way try to identify the module that its causing the mal functioning, but then i realize that i can ask you guys cause if it fails i will have to install every this again.
      I have suspicions about the auto starting magic mirror cause this starts to fail when i restart the raspberry pi 4.
      I also must say that everything works fine, its just the screen issue.
      Some passwords and id have been erased.
      /* Magic Mirror Config Sample
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
      var config = {
       address: "localhost",  // Address to listen on, can be:
       port: 8080,
       basePath: "/",  // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
       ipWhitelist: [],  // Set [] to allow all IP addresses
       useHttps: false,   // Support HTTPS or not, default "false" will use HTTP
       httpsPrivateKey: "",  // HTTPS private key path, only require when useHttps is true
       httpsCertificate: "",  // HTTPS Certificate path, only require when useHttps is true
       language: "es",
       timeFormat: 24,
       units: "metric",
         module: "MMM-Spotify",
         position: "top_bar",
           debug: false,
         module: "alert",
         module: "updatenotification",
         position: "top_bar"
         module: "clock",
          displaySeconds: false,
           module: 'MMM-GmailFeed',
           position: 'top_left',
         username: '',
         password: '',
         updateInterval: 30000,
         maxEmails: 5,
         maxSubjectLength: 20,
         maxFromLength: 10,
         playSound: true,
         autoHide: true,
         displayMode: "table",
         username: '',
         password: '',
         maxEmails: 5,
         maxFromLength: 10,
         playSound: true,
         autoHide: true,
           module: "currentweather",
         locationID: "3868121", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
         appid: ""
           module: "weatherforecast",
           header: "Pronóstico del clima",
         appid: ""
           module: "newsfeed",
           position: "bottom_bar",    // This can be any of the regions. Best results in center regions.
         // If no config is set, an example calendar is shown.
         feeds: [
           title: "Internacional",
           url: "https://www.elmostrador.cl/noticias/mundo/feed/",
           title: "Chile",
           url: "https://www.elmostrador.cl/destacado/feed/",
           title: "Ciencia",
           url: "https://www.investigacionyciencia.es/rss/noticias",
           title: "Tecnología",
           url: "https://es.digitaltrends.com/noticias/feed/",
          showSourceTitle: true,
          showPublishDate: true,
          broadcastNewsFeeds: true,
          broadcastNewsUpdates: true,
          showDescription: true,
          updateInterval: 15000
            module: 'MMM-Screencast',
            position: 'lower_third', // This position is for a hidden <div /> and not the screencast window
          position: 'middle',
          height: 1050,
          width: 1280,
           module: "MMM-MotionDetector",
           //position: "lower_third", // Optional. This can be any of the regions. Displays debug informations.
          timeout: "60000",
