    Config file Error - 'Split' Property
    12 Posts 2 Posters 1.8k Views 2 Watching
      paulyp2k6 @sdetweil
      @sdetweil So, I ran the Syntax check just now, like you suggested, and the Config file has no Syntax errors.
        sdetweil @paulyp2k6
        @paulyp2k6 ok, then do this
        npm start >somefile
        wait, hit ctrl-c
        and show us somefile
          paulyp2k6
          2021-01-27 18:49:34.496] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: Cannot read property ‘split’ of undefined
          [2021-01-27 18:49:34.501] [ERROR] App threw an error during load
          [2021-01-27 18:49:34.502] [ERROR] TypeError: Cannot read property ‘split’ of undefined
          at loadModule (/home/pi/MagicMirror/js/app.js:115:25)
          at loadNextModule (/home/pi/MagicMirror/js/app.js:169:5)
          at /home/pi/MagicMirror/js/app.js:171:6
          at loadModule (/home/pi/MagicMirror/js/app.js:153:4)
          at Class.loaded (/home/pi/MagicMirror/js/node_helper.js:18:3)
          at loadModule (/home/pi/MagicMirror/js/app.js:151:6)
          [2021-01-27 18:49:34.503] [ERROR] Whoops! There was an uncaught exception…
          [2021-01-27 18:49:34.504] [ERROR] TypeError: Cannot read property ‘split’ of undefined
          [2021-01-27 18:49:34.507] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [2021-01-27 18:49:34.508] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            sdetweil @paulyp2k6
            @paulyp2k6 can u post the config.js?
              paulyp2k6 @sdetweil
              /* Magic Mirror Config Sample
              • By Michael Teeuw https://michaelteeuw.nl
              • MIT Licensed.
              • For more information on how you can configure this file
              • See https://github.com/MichMich/MagicMirror#configuration
              var config = {
              // - “0.0.0.0”, “::” to listen on any interface
              // Default, when address config is left out or empty, is “localhost”
              port: 8080,
              basePath: “/”, // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
              ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
              // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
              // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
              language: "en",
              logLevel: ["INFO", "LOG", "WARN", "ERROR"],
              timeFormat: 24,
              units: "metric",
              		module: "alert"
              		module: "updatenotification",
              		position: "top_bar"
              		module: "clock",
              		position: "top_left"
              		module: "compliments",
              		position: "lower_third",
              			compliments: {
              			anytime: [
              				"Praise God!"
              			morning: [
              				"Say your morning offering",
              				"Live for others",
              				"Read Psalm 23"
              			afternoon: [
              				"Say the Angelus",
              				"Give Thanks to God",
              				"Looking good today!"
              			evening: [
              				"Do your Daily Examen",
              				"Have your prayed today?"
              		    module: 'MMM-OnThisDay',
              		    position: "top_center"
              		module: 'MMM-DailyBibleVerse',
              		position: 'bottom_bar',	// This can be any of the regions. Best result is in the bottom_bar as verses can take multiple lines in a day.
              			version: 'NIV', // This can be changed to any version you want that is offered by Bible Gateway. For a list, go here: https://www.biblegateway.com/versions/,
                  			size: 'small' // default value is medium, but can be changed.
              		  module: "MMM-MyScoreboard",
              		  position: "bottom_right",
              		  classes: "default everyone",
              		  header: "My Scoreboard",
              		    showLeagueSeparators: true,
              		    colored: true,
              		    viewStyle: "mediumLogos",
              		    sports: [
              			league: "NHL",
              			groups: ["Atlantic"]
              			league: "NBA",
              			teams: ["CHI"]
              			league: "MLB",
              			teams: ["CHC"],
              			groups: ["NL Central"]
              			league: "NFL",
              			teams: ["CHI"]
              			league: "ENGLISH_PREMIERE_LEAGUE"
              			league: "NCAAM_MM",
              			label: "March Madness"
              			league: "NCAAF",
              			label: "ILL",
              			groups: "Big Ten"
              		module: "currentweather",
              			units: "imperial",
              			locationID: "4916288", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
              			appid: "49865c49c53acd625df34235834afaa0"
              		module: "weatherforecast",
              		header: "Weather Forecast",
              			units: "imperial",
              		module: "newsfeed",
              		position: "bottom_bar",
              			feeds: [
              					title: "New York Times",
              					url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
              			showSourceTitle: true,
              			showPublishDate: true,
              			broadcastNewsFeeds: true,
              			broadcastNewsUpdates: true
              if (typeof module !== “undefined”) {module.exports = config;}
                sdetweil @paulyp2k6
                @paulyp2k6 said in Config file Error - 'Split' Property:
                module: ‘MMM-OnThisDay’,
                another modules array in the middle of the modules array?
                see the two topics in my signature below
                modules:[ … only once
                all module defs go in here, one after the other. nowhere else
                  paulyp2k6 @sdetweil
                  @sdetweil Holy smokes!! Thanks so much for your patience with me on this one. I am sorry that took so long. And thanks for the extra training modules.
                    sdetweil @paulyp2k6
                    @paulyp2k6 i didn’t write the others, just reference really good writers
