    Config file Error - 'Split' Property
    12 Posts 2 Posters 3.2k Views 2 Watching
      paulyp2k6
      Thanks so much, I will give that a try. In my college days the most frequent error was a missing semi-colon. Now it seems to be missing commas. Syntax will always be my downfall. But, thanks for the help.
        sdetweil @paulyp2k6
        @paulyp2k6 javascript is pretty straightforward in data definitions. allows comments, cause its ‘code’, vs json which is not, and very precise
        P 1 Reply Last reply
          paulyp2k6 @sdetweil
          @sdetweil So, I ran the Syntax check just now, like you suggested, and the Config file has no Syntax errors.
            sdetweil @paulyp2k6
            @paulyp2k6 ok, then do this
            npm start >somefile
            wait, hit ctrl-c
            and show us somefile
              paulyp2k6
              2021-01-27 18:49:34.496] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: Cannot read property ‘split’ of undefined
              [2021-01-27 18:49:34.501] [ERROR] App threw an error during load
              [2021-01-27 18:49:34.502] [ERROR] TypeError: Cannot read property ‘split’ of undefined
              at loadModule (/home/pi/MagicMirror/js/app.js:115:25)
              at loadNextModule (/home/pi/MagicMirror/js/app.js:169:5)
              at /home/pi/MagicMirror/js/app.js:171:6
              at loadModule (/home/pi/MagicMirror/js/app.js:153:4)
              at Class.loaded (/home/pi/MagicMirror/js/node_helper.js:18:3)
              at loadModule (/home/pi/MagicMirror/js/app.js:151:6)
              [2021-01-27 18:49:34.503] [ERROR] Whoops! There was an uncaught exception…
              [2021-01-27 18:49:34.504] [ERROR] TypeError: Cannot read property ‘split’ of undefined
              [2021-01-27 18:49:34.507] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              [2021-01-27 18:49:34.508] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                sdetweil @paulyp2k6
                @paulyp2k6 can u post the config.js?
                  paulyp2k6 @sdetweil
                  /* Magic Mirror Config Sample
                  • By Michael Teeuw https://michaelteeuw.nl
                  • MIT Licensed.
                  • For more information on how you can configure this file
                  • See https://github.com/MichMich/MagicMirror#configuration
                  var config = {
                  // - “0.0.0.0”, “::” to listen on any interface
                  // Default, when address config is left out or empty, is “localhost”
                  port: 8080,
                  basePath: “/”, // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                  ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
                  // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                  // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                  language: "en",
                  logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                  timeFormat: 24,
                  units: "metric",
                  		module: "alert"
                  		module: "updatenotification",
                  		position: "top_bar"
                  		module: "clock",
                  		position: "top_left"
                  		module: "compliments",
                  		position: "lower_third",
                  			compliments: {
                  			anytime: [
                  				"Praise God!"
                  			morning: [
                  				"Say your morning offering",
                  				"Live for others",
                  				"Read Psalm 23"
                  			afternoon: [
                  				"Say the Angelus",
                  				"Give Thanks to God",
                  				"Looking good today!"
                  			evening: [
                  				"Do your Daily Examen",
                  				"Have your prayed today?"
                  		    module: 'MMM-OnThisDay',
                  		    position: "top_center"
                  		module: 'MMM-DailyBibleVerse',
                  		position: 'bottom_bar',	// This can be any of the regions. Best result is in the bottom_bar as verses can take multiple lines in a day.
                  			version: 'NIV', // This can be changed to any version you want that is offered by Bible Gateway. For a list, go here: https://www.biblegateway.com/versions/,
                      			size: 'small' // default value is medium, but can be changed.
                  		  module: "MMM-MyScoreboard",
                  		  position: "bottom_right",
                  		  classes: "default everyone",
                  		  header: "My Scoreboard",
                  		    showLeagueSeparators: true,
                  		    colored: true,
                  		    viewStyle: "mediumLogos",
                  		    sports: [
                  			league: "NHL",
                  			groups: ["Atlantic"]
                  			league: "NBA",
                  			teams: ["CHI"]
                  			league: "MLB",
                  			teams: ["CHC"],
                  			groups: ["NL Central"]
                  			league: "NFL",
                  			teams: ["CHI"]
                  			league: "ENGLISH_PREMIERE_LEAGUE"
                  			league: "NCAAM_MM",
                  			label: "March Madness"
                  			league: "NCAAF",
                  			label: "ILL",
                  			groups: "Big Ten"
                  		module: "currentweather",
                  			units: "imperial",
                  			locationID: "4916288", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                  			appid: "49865c49c53acd625df34235834afaa0"
                  		module: "weatherforecast",
                  		header: "Weather Forecast",
                  			units: "imperial",
                  		module: "newsfeed",
                  		position: "bottom_bar",
                  			feeds: [
                  					title: "New York Times",
                  					url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                  			showSourceTitle: true,
                  			showPublishDate: true,
                  			broadcastNewsFeeds: true,
                  			broadcastNewsUpdates: true
                  if (typeof module !== “undefined”) {module.exports = config;}
                    sdetweil @paulyp2k6
                    @paulyp2k6 said in Config file Error - 'Split' Property:
                    module: ‘MMM-OnThisDay’,
                    another modules array in the middle of the modules array?
                    see the two topics in my signature below
                    modules:[ … only once
                    all module defs go in here, one after the other. nowhere else
                      paulyp2k6 @sdetweil
                      @sdetweil Holy smokes!! Thanks so much for your patience with me on this one. I am sorry that took so long. And thanks for the extra training modules.
                        sdetweil @paulyp2k6
                        @paulyp2k6 i didn’t write the others, just reference really good writers
