MMM-PIR-Sensor
 @maxxmagic said in MMM-PIR-Sensor: The install is complete new with the newest raspian and the newest version of MM and so on. Have you also switched on the GPIO’s in the RASPBIAN operating system?
 @icemanmw What du you mean exactly by turning on the gpio? I added the user to the gpio group and the indicator shows that it detecting movement. So let me know, which command do you by turning on the gpio. Thank you in advance :)
 Thanks, I thought the remote connection is for entering the GPIO via LAN because the setup is completely wired at the pi. Best :)
 Max
 Unfortunatley, it doens not change any behavior. If I pu in this in to the command line: gpio read 25 Unable to determine hardware version. I see: Hardware : BCM2835 , - expecting BCM2708 or BCM2709. Please report this to projects@drogon.netI got this error. Could this be related to the problem with the screen? Best,
 Max
