    Rotating Display Screen
    14 Posts 2 Posters 3.8k Views 2 Watching
      brendan_c23
      I need to rotate my screen from landscape to a portrait display. Basically rotate the current display 90 degrees clockwise. I am displaying the Pi through a TV but have rotated the TV so the long side is going straight up and down instead of left to right. I have tried this by clicking the raspberry button in the top left corner and Preferences > Screen Configuration > Right-click HDMI-2 > Orientation > Left > Green check mark , but after confirming the changes, nothing happens. Any help would be appreciated, thank you
        sdetweil @brendan_c23
        @brendan_c23 hdmi-2???
          brendan_c23 @sdetweil
            @sdetweil It comes up in the in the Screen Layout Editor as that because I have it pugged into HDMI2 on the tv
              @brendan_c23 pi doesnt know. pi4 has hdmi1, left port , and hdmi2, right port.
              no relation to tv source
              my tv has 4 ports
              i have pi 0, pi 3, pi4, and jetson nano on tv sources
              all pis think they are using hardware port hdmi1
                @sdetweil How can I rotate the display 90 degrees clockwise?
                  @brendan_c23 i think you were doing it correctly, but not using right hardware port
                    @sdetweil HDMI-2 is the only option that comes up in the Screen layout editor. I just checked and I have the hdmi cord plugged into the main micro hdmi port on the pi and HDMI 1 port on TV.
                      @brendan_c23 is this a pi4?
                      main is the one next to power supply
                        @sdetweil yes and yes its plugged in the main next to power supply
                          @brendan_c23 hm that worked for me last time i tried (couple of months)
                            @sdetweil is there a way to do it manually through code?
                              @brendan_c23 no idea
                              did u reboot after any of those changes?
                                @sdetweil yes and no luck
