    MMM-Traffic
    7 Posts 3 Posters 2.0k Views 4 Watching
    • G Offline
      Gr1dL0ck
      trying to configure this module
      https://github.com/SamLewis0602/MMM-Traffic
      got a token from Mapbox as per the instructions, got it to appear on my MM, but just says ‘loading’
      nothing ever comes up ??
      module: “MMM-Traffic”,
      position: “top_left”,
      accessToken: “your_key_here”,
      originCoords: “-84.398848,33.755165”,
      destinationCoords: “-84.504259,33.88210”,
      firstLine: “{duration} mins”,
      secondLine: “Home To School”,
      • G Offline
        Gr1dL0ck @Gr1dL0ck
        @gr1dl0ck
        in my Mapbox account i see there have been 11 API requests (from 100,000 free) using the ‘default public token’ in the account page.
        so i think its using the data, but my MM is just sitting on :
        (car icon) Loading …
          sdetweil @Gr1dL0ck
          @gr1dl0ck can u look at the terminal window where u start mm to see the messages.
          if you use pm2, then the pm2 logs --lines=???
          command,
          where ??? is a number, default 15,
          will show this info
          also open the developers window, ctrl-shift-i on the mm keyboard, and select the console tab
          you can filter messages by module, by putting part of the module name in the filter field,
          traff should be enough.
          show any errors (usually red text)
          • G Offline
            Gr1dL0ck @sdetweil
            The console logs display this, sorry dont know what it means
            Uncaught TypeError: console.log is not a function   MMM-Traffic.js.135
                 at Class.socketNotificationRecieved (MMM-Traffic.js.135)
                 at module.js.250
                 at socket. <anonymous> (socketclient.js.39)
                 at Socket../node_modules/component-emitter/index.js.Emitter.Emit (index.js.145)
                 at Socket.emitEvent (socket.js.253)
                 at Socket.onevent (socket.js.240)
                 at Socket.MMSocket.self.socket.onevent (socketclient.js.33)
                 at Socket.onpacket (socket.js.204)
                 at Manager.<anonymous>  (index.js.21)
              SamLewis0602 @Gr1dL0ck
              MMM-Traffic author here, just wanted to post here on the forum that this was resolved in a Github issue here: https://github.com/SamLewis0602/MMM-Traffic/issues/95
              This is caused by a different module, the MMM-GoogleMapsTraffic module, as seen in this unmerged PR here: https://github.com/vicmora/MMM-GoogleMapsTraffic/pull/24
              Anyone using both that module and my module in their mirror would see MMM-Traffic stuck on loading. Judging by the activity on that other module, it looks to be unsupported. See the issue I linked on my repo above for a manual fix if you wish to use both modules together.
                sdetweil @SamLewis0602
                @samlewis0602 I have the fixed Googlemapstraffic module on my github
                https://github.com/sdetweil/MMM-GoogleMapsTraffic
                  SamLewis0602 @sdetweil
                  @sdetweil Good to know, I’ll point people this way if I see it again.
