    Calendar date format
    16 Posts 5 Posters 9.1k Views 5 Watching
    • G Offline
      Gr1dL0ck
      evening all,
      I just need to change the format on my calendar for up coming events which is being displayed in US format MM/DD/YYYY
      I would like to change it to DD MMM
      module: “calendar”,
      header: “AU Holidays”,
      position: “top_left”,
      dateformat: “DD MMM”,
      symbol: “calendar-check”,
      url: “https://calendar.google.com…” }
      https://docs.magicmirror.builders/modules/calendar.html#configuration-options
      where does the ‘dateformat’ go?
      IS DD MMM a correct format?
        sdetweil @Gr1dL0ck
        @gr1dl0ck please reade the documentation
        https://docs.magicmirror.builders/modules/calendar.html#using-the-module
        G 1 Reply Last reply Reply Quote -1
        • G Offline
          Gr1dL0ck @sdetweil
          i get it sam, you can paste the user guide and documents all day. i have read them but dont understand the format them hence my posts.
            sdetweil @Gr1dL0ck
            @gr1dl0ck all the config parameters are case sensitive.
            so dateformat and dateFormat (from the doc) are not the same.
            and there is an example that shows where is goes.
            • G Offline
              Gr1dL0ck @sdetweil
              this is my current config code, i have tried placing it in both positions as shown (one at a time) still doesnt change anything on the calendar.
              I got the ‘L’ command from here https://momentjs.com/docs/#/parsing/string-format/
              DD MMM didnt work
              module: “calendar”,
              dateFormat: “L”,
              url: “https://calendar.google.com……”
              dateFormat: “L”,
                sdetweil @Gr1dL0ck
                @gr1dl0ck because the option is described in the ‘Configuration Options’ section, it goes above the individual calendars
                but it also says ‘when using absolute formats’
                by default the calendar is showing relative formats…
                so u also need to set
                showTime:"absolute",
                • G Offline
                  Gr1dL0ck @sdetweil
                  does the showtime: “absolute”, go out of the modules up where it has language, log level, timeformat, units?
                  i tried in there didnt make any difference
                  i put in down in the module in serval places didnt change, tried both “L” and “DD MMM” on the dateFormat.
                         module: “calendar”,
                                               dateFormat: “L”,
                    sdetweil @Gr1dL0ck
                    @gr1dl0ck come on. read the doc…
                    you are configuring a module, so any options would ONLY be inside a module config:{} block
                    and remember the system is case sensitive. every letter matters
                    the doc describes 2 areas of config,
                    calendars and NOT calendars
                    all the NOT calendar opitions go INSIDE MODULE CONFIG and BEFORE the CALENDARS list
                    all the calendar config, goes with each calendar entry
                    • G Offline
                      Gr1dL0ck @sdetweil
                      not sure if this is what you mean, but still nothing changes, all dates are still MM/DD/YYYY
                      Showtime: “absolute”, no idea where this is mentioned in the document, unsure where it goes.
                      dateFormat - config option, in the configuration
                      // If no config is set, an example calendar is shown.
                      // See ‘Configuration options’ for more information.
                             module: “calendar”,
                                        showtime: "absolute",
                                       dateFormat: “DD MMM”,
                      as for reading the document, I have ctrl+f ’ showtime’ , ‘Not calendar’ all these things you mention in each post, so unless we are reading different documents … I have zero idea where you are getting the information from
                      you can keep being condescending as much as you want, trying my best i have been doing this for around 7 days.
                      This thread could of been 3 posts long, describe the issue, post an answer with an explanation and a last reply of thankyou this helps alot.
                        sdetweil @Gr1dL0ck
                        @gr1dl0ck i will NOT give u the answer. cause u will be back for another.
                        my job as moderator here is to teach u and direct you to info.
                        the doc is the online readme referenced in the README.md in the calendar module folder
                        https://github.com/MichMich/MagicMirror/tree/master/modules/default/calendar
                        this is the same doc file name for everything
                        and sometimes i dont look.up the exact config term, cause i expect you to do.it
                        G P 2 Replies Last reply Reply Quote -3
                        • G Offline
                          Gr1dL0ck @sdetweil
                          mine doesn’t even display the default date as per this doc, I would copy a picture but it has a bunch of private appointments in there.
                          Default value: MMM Do (e.g. Jan 18th)
                          mine displays (for example)
                          'appointment 03/10/2021
                            mrega @Gr1dL0ck
                            @gr1dl0ck
                            Try this…
                            		header: "AR Holidays",
                            			fade : false,
                            			timeFormat : "absolute",
                            	                fullDayEventDateFormat : "DD-MM-YYYY",
                            				        symbol: "calendar-check",
                            					    url: "https://calendar.google.com/sic.ics",
                            						auth: {
                            							user: '',
                            							pass: '',
                            							method: 'basic'
                            G 1 Reply Last reply Reply Quote 2
                            • G Offline
                              Gr1dL0ck @mrega
                              @mrega you were close
                              fade : false,
                              dateFormat : "DD MMM",
                              that fixed it thank you !
                              can you explain what the follow is 'Fade: false/ true ’ what does this refer to or alter?
                              and what does the “absolute” refer back too ?
                                pigeonshouse @sdetweil
                                @sdetweil along with the ‘block everyone who disagrees with me’ Wikipedia admins. I have come across people on linux forums who act like yourself over the past 25 years and usually, it implies someone doesn’t actually know the answer and simply dragging their feet/wasting everyones time because of it. I guess at least one saving grace is that there aren’t any getting people to compile libraries with debug symbols for ‘helpful’ people to dither over and never reply to.
                                It’s tiring. If you don’t want to actually provide any assistance then why are you even replying? You could have helped and also made others like myself feel that the MM community is welcoming. On first impressions, I have seen this and it thought “you know what, why bother even looking here for assistance if the reps are going to be like this”.
                                  sdetweil @pigeonshouse
                                  @pigeonshouse thank you for your criticism. sadly the user didn’t learn how to take care of his own system, but is dependent on others to tell him what to type/copy paste.
                                  I am a volunteer, here because I like to be. I am NOT a copy/paster type. I will make you work, and learn in the process.
                                  O 1 Reply Last reply Reply Quote -2
                                  • O Offline
                                    OberfragGER @sdetweil
                                    I just wrote the Question and before sending i found the “solution”.
                                    Today is the 29th August 2021
                                    Calendar now shows “29. August 2021” (“LL”)
                                    I just want to have “29. August”. Thats just
                                    dateFormat: 'D.MMMM',
                                    I`ll keep it here for others if they search for it too. Did´nt found that in the docu somehow.
