    Wrong weather icons showing on Weather Forecast module
    8 Posts 2 Posters 1.2k Views 2 Watching
    • F Offline
      FryskeMon @JerryP
      @jerryp of wil je de volledige config hebben?
      JerryPJ 1 Reply Last reply Reply Quote 0
      • JerryPJ Offline
        JerryP @FryskeMon
        @fryskemon
        First off all. you must write in Englich. Or Dutch in PB
        Whitch API u use… at openwheater you can select a view.
        And why ar you use a update time of every miniut??
        Standaard that is set to 10 min.
        And the MaxNumberofdays is also standaar set to 7
        module: “weatherforecast”,
        position: “top_right”,
        header: “Het weer in”,
        locationID: “2756644”,
        appid: “TopSecrute”,
        updateInterval: “60000”,  //Waarom iedere minuut standaard staat deze op 10 minuten!!
        units: metric,
        showRainAmount: true,
        colored: true,
        scale: true,
        fade: false,
        • F Offline
          FryskeMon @JerryP
          @jerryp
          Oh sorry wasn’t aware of it.
          I use the Call 5 day / 3 hour forecast data.
          I use the default API key.
          Changed the update time to default and removed the maxnumberofdays.
          But still it gives me the wrong icons.
          This is my code now:
          			module: "weatherforecast",
          			header: "Het weer in",
          				locationID: "2756644",
          				appid: "xxxx",
          				colored: true,
          				scale: true,
          				fade: false,
          • JerryPJ Offline
            JerryP @FryskeMon
            @fryskemon
            yes thats looks the same at mine
            • F Offline
              FryskeMon @JerryP
              @jerryp
              Okay but I still have the wrong icons
              It is still displaying sunny weather on monday where it should display light rain.
