    Wrong weather icons showing on Weather Forecast module
    8 Posts 2 Posters 1.3k Views 2 Watching
    • F Offline
      FryskeMon
      I installed the standard weather forecast module today. The problem is that the module does not show the right icons depending on the weather. For example it will be rainy on monday, as it says on openweathermap.org. The icon that shows is a sun. Can anybody help me fix this?Schermafbeelding 2021-03-04 om 14.53.12.png )Schermafbeelding 2021-03-04 om 14.53.42.png
      JerryPJ 1 Reply Last reply Reply Quote 0
      • JerryPJ Online
        JerryP @FryskeMon
        @fryskemon Can you pleas put the config online??? So I can check for you.
        NL:
        Wil je de config file even mee posten dan kan ik even met je mee kijken.
        F 2 Replies Last reply Reply Quote 0
        • F Offline
          FryskeMon @JerryP
          @jerryp
          module: “weatherforecast”,
          position: “top_right”,
          header: “Het weer in”,
          locationID: “2756644”, //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          appid: “xxxxx”,
          updateInterval: “60000”,
          showRainAmount: true,
          colored: true,
          scale: true,
          fade: false,
          maxNumberOfDays: 7,
          • F Offline
            FryskeMon @JerryP
            @jerryp of wil je de volledige config hebben?
            • JerryPJ Online
              JerryP @FryskeMon
              @fryskemon
              First off all. you must write in Englich. Or Dutch in PB
              Whitch API u use… at openwheater you can select a view.
              And why ar you use a update time of every miniut??
              Standaard that is set to 10 min.
              And the MaxNumberofdays is also standaar set to 7
              appid: “TopSecrute”,
              updateInterval: “60000”,  //Waarom iedere minuut standaard staat deze op 10 minuten!!
              units: metric,
              colored: true,
              scale: true,
              fade: false,
              • F Offline
                FryskeMon @JerryP
                @jerryp
                Oh sorry wasn’t aware of it.
                I use the Call 5 day / 3 hour forecast data.
                I use the default API key.
                Changed the update time to default and removed the maxnumberofdays.
                But still it gives me the wrong icons.
                This is my code now:
                			module: "weatherforecast",
                			header: "Het weer in",
                				locationID: "2756644",
                				appid: "xxxx",
                				colored: true,
                				scale: true,
                				fade: false,
                • JerryPJ Online
                  JerryP @FryskeMon
                  @fryskemon
                  yes thats looks the same at mine
                  • F Offline
                    FryskeMon @JerryP
                    @jerryp
                    Okay but I still have the wrong icons
                    It is still displaying sunny weather on monday where it should display light rain.
