    Voice command to open videos
    6 Posts 4 Posters 1.5k Views 4 Watching
      bigjojo
      I use GA assistant from bugsounet who no longer posts on this forum because he made his own forum, see on his github.
      I made a recipe which allows me to run the raspbian vlc in full screen. which allows me to either launch a video (christmas tree or halloween) but especially watch the streaming stream from my dreambox directly on the mirror. when i stop looking i just say jarvis stop vlc and he comes back to the mirror.
      I put an example of my recipe so you can have fun.
      I speak French so see to change the sentences in your language.
      bye.
      var recipe = {
      transcriptionHooks: {
      “miroir vidéo”: {
      pattern: “regarder miroir vidéo”,
      command: “miroir_vidéo”
      “rtsun”: {
      pattern: “regarder rts1”,
      command: “rtsun”
      },“stop_vlc”: {
      pattern: “stopper vlc”,
      command: “stop_vlc”
      commands: {
      “miroir_vidéo”: {
      soundExec: {
      chime: “close”,
      shellExec: {
      exec: “vlc -f file:///home/pi/MagicMirror/video/02.mp4”
      “rtsun”: {
      soundExec: {
      chime: “close”,
      shellExec: {
      exec: “vlc -f http://...:****/1:0:19:4333:300C:13E:820000:0:0:0:”
      “stop_vlc”: {
      soundExec: {
      chime: “close”,
      shellExec: {
      exec: “killall vlc”
      exports.recipe = recipe // Don’t remove this line.
        the path to local videos for url loading is
        http://localhost:port/modules/???/videofile.name
        note they have to be in the mm modules folder tree to be able to use the mm server to load them
          pbetre
          @bigjojo
          Bonsoir,
          Bon travail, pourriez-vous me donner des explications sur la ligne suivante :
          exec: “vlc -f http://…:****/1:0:19:4333:300C:13E:820000:0:0:0:”
          merci d’avance,
          Cordialement,
          Paul
            bigjojo @pbetre
            @pbetre
            c’est la ligne qui correspond a une chaine télé de ma dreambox.
            a vous de changer, je pense que sa doit être possible de mettre une ligne pour de l’iptv ou autres.
            sur le 1er exemple
            quand je dis regarder miroir vidéo, il m’ouvre un fichier vidéo stocké dans le chemin plus bas.
            c’est simplement un vidéo pour un effet a halloween ou encore a noël, il me mets un sapin.
            sur le 2 eme exemple
            je lui demande de regarder une chaine télé ici rts1 et il va chercher le lien de ma démodulateur satellite pour l’afficher.
            cordialement
              pbetre @bigjojo
              @bigjojo
              Merci, j’ai essayé, ça marche.
              cordialement,
              Paul
