    Development Branch -- Screen Going Blank
    13 Posts 2 Posters 5.2k Views 2 Watching
      sdetweil @yk
      @yk also consider increasing the system swap space
      • Y
        yk @sdetweil
        @sdetweil that’s a good point. It happened again - I gather that’s probably a best option.
        Keep me honest, is the below the best approach?
        For others searching in the future:
        1. sudo dphys-swapfile swapoff
        2. sudo nano /etc/dphys-swapfile
        3. update CONF_SWAPSIZE to something like 1024
        4. save file (ctrl + x)
        5. sudo dphys-swapfile setup
        6. sudo dphys-swapfile swapon
        7. sudo reboot
        You’re probably right, need to increase. Mine is set to 100 at the moment.
          sdetweil @yk
          @yk yes, good steps
          free -m
          will tell you if any has been used
          • Y
            yk @sdetweil
            @sdetweil keeps happening unfortunately. it might be time to start removing modules to see if that helps.
            Two errors seen:
            out of memory error and also saw a fatal: unable to access ‘https://github.com/MichMich/MagicMirror.git/’: gnutls_handshake() failed: Error in the push function.
            I’m only using:
            MMM-MyWastePickup (only uses local file)
            MMM-Unsplash (hits Unsplash twice an hour)
            MMM-DarkSkyForecast
            MMM-Tools
            Calendar does an iCloud refresh using vdirsyncer (every 30 minutes)
            Calendar-Fetcher looks to be doing a broadcasting of events every 10 to 12 minutes. Not sure what this is.
            mem total=925 / used=272
            swap total=1023 / used=116
            I wonder if the iCloud hit happens at the same time as the Unsplash hit causing an issue.
              sdetweil @yk
              @yk said in Development Branch -- Screen Going Blank:
              if swap was 100, now 116 meg used.
              memory 272 used doesn’t make sense
              • Y
                yk @sdetweil
                @sdetweil sorry
                I bumped up the swap already to 1024
                memory
                total = 925
                used = 272
                swap
                total=1023
                used=116
                  sdetweil @yk
                  @yk shouldn’t have used any swap if u still have free main memory
                  Y 2 Replies Last reply Reply Quote 0
                  • Y
                    yk @sdetweil
                    @sdetweil agreed.
                    But i’m seeing the below after another memory issue today.
                    type total used free shared buff/cache availabl
                    Mem: 925 291 367 9 267 571
                    Swap: 1023 93 930
                    • Y
                      yk @sdetweil
                      @sdetweil I’m working with the developer of MMM-Unsplash. This might be down the the usage of “raw”. Will revert.
                      Separately, just to confirm: no issue with calendar fetcher broadcasting every 10 minutes? What is it doing? (can you tell I’m sniffing everything now?) ;)
                      • Y
                        yk @yk
                        @sdetweil let’s close this one. There was a need to pass through a height or width value when using MMM-Unsplash. Passing nothing seems to have grabbed the raw file and chewed up a good deal of memory. I’m still monitoring.
                        I’d love to setup a log element that drops memory usage into the pm2 logs. Just fear monitoring memory may eat up too much memory ;) (but I should have plenty of it)
                        I’m using MMM-Tools to display stats, may leverage that.
