MMM-CalendarExt2 Site can't be reached
8 Posts 3 Posters 1.0k Views 3 Watching
    Marc Rosay
    hello, I can’t display my calendar, it works with the basic calendar but not with MMM-CalendarExt2, I used the code example, but magic mirror shows me “This site can’t be reached”, I have the same with MMM-CalendarExt.
    For information, I work with a raspberry pi zero W.
    Could someone help me please ?
    S 1 Reply Last reply Mar 22, 2021, 12:57 PM Reply Quote 0
      sdetweil @Marc Rosay
      @marc-rosay can u show us the url you use?
      change some characters near the end so it doesn’t work
      M 1 Reply Last reply Mar 22, 2021, 4:45 PM Reply Quote 0
        Marc Rosay @sdetweil
        @sdetweil thank you for the help !
        it doesn’t work with this :
        https://www.google.com/calendar/ical/ovb564thnod82u5c4njut98728%40group.calendar.google.com/public/basic.ics
        this is the url in the example
        S 1 Reply Last reply Mar 22, 2021, 5:00 PM Reply Quote 0
          @marc-rosay is there any message in the window where u start MM? npm start or pm2 start??
          if pm2, then use the pm2 logs --lines=?? ?? is a number, default 15
          M 1 Reply Last reply Mar 22, 2021, 5:59 PM Reply Quote 0
            Marc Rosay
            @sdetweil here is the errors it gives, but i’m not sure to understand…
            0|mmstart  | [22.03.2021 18:32.13.033] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'valid-url'
            0|mmstart  | [22.03.2021 18:32.13.084] [ERROR] Whoops! There was an uncaught exception...
            0|mmstart  | [22.03.2021 18:32.13.139] [ERROR] { Error: Cannot find module 'valid-url'
            0|mmstart  |     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
            0|mmstart  |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
            0|mmstart  |     at Function.Module._load (internal/modules/cjs/loader.js:562:25)
            0|mmstart  |     at Module.require (internal/modules/cjs/loader.js:690:17)
            0|mmstart  |     at require (internal/modules/cjs/helpers.js:25:18)
            0|mmstart  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-CalendarExt2/node_helper.js:3:18)
            0|mmstart  |     at Module._compile (internal/modules/cjs/loader.js:776:30)
            0|mmstart  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
            0|mmstart  |     at Module.load (internal/modules/cjs/loader.js:653:32)
            0|mmstart  |     at tryModuleLoad (internal/modules/cjs/loader.js:593:12) code: 'MODULE_NOT_FOUND' }
            0|mmstart  | [22.03.2021 18:32.13.149] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            0|mmstart  | [22.03.2021 18:32.13.159] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            0|mmstart  |
            0|mmstart  |
            0|mmstart  | X.Org X Server 1.20.4
            0|mmstart  | X Protocol Version 11, Revision 0
            0|mmstart  | Build Operating System: Linux 4.15.0-48-generic armv8l Raspbian
            0|mmstart  | Current Operating System: Linux raspberrypi 4.19.97+ #1294 Thu Jan 30 13:10:54 GMT 2020 armv6l
            0|mmstart  | Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=1600 bcm2708_fb.fbheight=900 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:EA:17:C7 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  console=ttyS0,115200 console=tty1 root=PARTUUID=738a4d67-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
            0|mmstart  | Build Date: 05 June 2019  12:49:54PM
            0|mmstart  | xorg-server 2:1.20.4-1+rpt1 (https://www.debian.org/support)
            0|mmstart  | Current version of pixman: 0.36.0
            0|mmstart  |    Before reporting problems, check http://wiki.x.org
            0|mmstart  |    to make sure that you have the latest version.
            0|mmstart  | Markers: (--) probed, (**) from config file, (==) default setting,
            0|mmstart  |    (++) from command line, (!!) notice, (II) informational,
            0|mmstart  |    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
            0|mmstart  | (==) Log file: "/var/log/Xorg.0.log", Time: Mon Mar 22 18:32:36 2021
            0|mmstart  | (==) Using system config directory "/usr/share/X11/xorg.conf.d"
            0|mmstart  | [589:589:0322/183259.671712:ERROR:gl_implementation.cc(282)] Failed to load libGLESv2.so.2: libGLESv2.so.2: cannot open shared object file: No such file or directory
            0|mmstart  | [589:589:0322/183259.829795:ERROR:viz_main_impl.cc(176)] Exiting GPU process due to errors during initialization
            0|mmstart  | [547:893:0322/183307.059505:ERROR:object_proxy.cc(632)] Failed to call method: org.freedesktop.DBus.Properties.Get: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
            0|mmstart  | [547:893:0322/183307.082801:ERROR:object_proxy.cc(632)] Failed to call method: org.freedesktop.UPower.GetDisplayDevice: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
            0|mmstart  | [547:893:0322/183307.111738:ERROR:object_proxy.cc(632)] Failed to call method: org.freedesktop.UPower.EnumerateDevices: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
            0|mmstart  | Fontconfig error: Cannot load default config file
              @sdetweil I found the solution,
              thank you !
              i had to install valid-url :
              npm install valid-url
              R 1 Reply Last reply Oct 6, 2021, 12:41 AM Reply Quote 0
                robwaddell @Marc Rosay
                @marc-rosay I can not get this to work. I’ve tried the npm install valid-url
                and I still get a white screen that says local host refused to connect
                S 1 Reply Last reply Oct 6, 2021, 12:44 AM Reply Quote 0
                  sdetweil @robwaddell
                  @robwaddell localhost means on this machine…
                  none of your urls should point to localhost
                  can u show us the calendars definition from this module… u can change some of the characters in the mangled name, try not to leave out any lines…
