    MMM-CalendarExt2 Site can't be reached
    8 Posts 3 Posters 1.4k Views 3 Watching
      Marc Rosay
      hello, I can’t display my calendar, it works with the basic calendar but not with MMM-CalendarExt2, I used the code example, but magic mirror shows me “This site can’t be reached”, I have the same with MMM-CalendarExt.
      For information, I work with a raspberry pi zero W.
      Could someone help me please ?
        sdetweil @Marc Rosay
        @marc-rosay can u show us the url you use?
        change some characters near the end so it doesn’t work
          Marc Rosay @sdetweil
          @sdetweil thank you for the help !
          it doesn’t work with this :
          https://www.google.com/calendar/ical/ovb564thnod82u5c4njut98728%40group.calendar.google.com/public/basic.ics
          this is the url in the example
            @marc-rosay is there any message in the window where u start MM? npm start or pm2 start??
            if pm2, then use the pm2 logs --lines=?? ?? is a number, default 15
              Marc Rosay
              @sdetweil here is the errors it gives, but i’m not sure to understand…
              0|mmstart  | [22.03.2021 18:32.13.033] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'valid-url'
              0|mmstart  | [22.03.2021 18:32.13.084] [ERROR] Whoops! There was an uncaught exception...
              0|mmstart  | [22.03.2021 18:32.13.139] [ERROR] { Error: Cannot find module 'valid-url'
              0|mmstart  |     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
              0|mmstart  |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
              0|mmstart  |     at Function.Module._load (internal/modules/cjs/loader.js:562:25)
              0|mmstart  |     at Module.require (internal/modules/cjs/loader.js:690:17)
              0|mmstart  |     at require (internal/modules/cjs/helpers.js:25:18)
              0|mmstart  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-CalendarExt2/node_helper.js:3:18)
              0|mmstart  |     at Module._compile (internal/modules/cjs/loader.js:776:30)
              0|mmstart  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
              0|mmstart  |     at Module.load (internal/modules/cjs/loader.js:653:32)
              0|mmstart  |     at tryModuleLoad (internal/modules/cjs/loader.js:593:12) code: 'MODULE_NOT_FOUND' }
              0|mmstart  | [22.03.2021 18:32.13.149] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              0|mmstart  | [22.03.2021 18:32.13.159] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              0|mmstart  |
              0|mmstart  |
              0|mmstart  | X.Org X Server 1.20.4
              0|mmstart  | X Protocol Version 11, Revision 0
              0|mmstart  | Build Operating System: Linux 4.15.0-48-generic armv8l Raspbian
              0|mmstart  | Current Operating System: Linux raspberrypi 4.19.97+ #1294 Thu Jan 30 13:10:54 GMT 2020 armv6l
              0|mmstart  | Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=1600 bcm2708_fb.fbheight=900 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:EA:17:C7 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  console=ttyS0,115200 console=tty1 root=PARTUUID=738a4d67-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
              0|mmstart  | Build Date: 05 June 2019  12:49:54PM
              0|mmstart  | xorg-server 2:1.20.4-1+rpt1 (https://www.debian.org/support)
              0|mmstart  | Current version of pixman: 0.36.0
              0|mmstart  |    Before reporting problems, check http://wiki.x.org
              0|mmstart  |    to make sure that you have the latest version.
              0|mmstart  | Markers: (--) probed, (**) from config file, (==) default setting,
              0|mmstart  |    (++) from command line, (!!) notice, (II) informational,
              0|mmstart  |    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
              0|mmstart  | (==) Log file: "/var/log/Xorg.0.log", Time: Mon Mar 22 18:32:36 2021
              0|mmstart  | (==) Using system config directory "/usr/share/X11/xorg.conf.d"
              0|mmstart  | [589:589:0322/183259.671712:ERROR:gl_implementation.cc(282)] Failed to load libGLESv2.so.2: libGLESv2.so.2: cannot open shared object file: No such file or directory
              0|mmstart  | [589:589:0322/183259.829795:ERROR:viz_main_impl.cc(176)] Exiting GPU process due to errors during initialization
              0|mmstart  | [547:893:0322/183307.059505:ERROR:object_proxy.cc(632)] Failed to call method: org.freedesktop.DBus.Properties.Get: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
              0|mmstart  | [547:893:0322/183307.082801:ERROR:object_proxy.cc(632)] Failed to call method: org.freedesktop.UPower.GetDisplayDevice: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
              0|mmstart  | [547:893:0322/183307.111738:ERROR:object_proxy.cc(632)] Failed to call method: org.freedesktop.UPower.EnumerateDevices: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
              0|mmstart  | Fontconfig error: Cannot load default config file
                @sdetweil I found the solution,
                thank you !
                i had to install valid-url :
                npm install valid-url
                  robwaddell @Marc Rosay
                  @marc-rosay I can not get this to work. I’ve tried the npm install valid-url
                  and I still get a white screen that says local host refused to connect
                    sdetweil @robwaddell
                    @robwaddell localhost means on this machine…
                    none of your urls should point to localhost
                    can u show us the calendars definition from this module… u can change some of the characters in the mangled name, try not to leave out any lines…
