    Need help resizing in vertical orientation
    36 Posts 3 Posters 14.3k Views 3 Watching
      Matthewlawson3
      Hi, I have been working on my magic mirror and everything is working great! Today I flipped the orientation of the mirror to vertical. Most of the modules that I have work great in the vertical orientation, however, a few, like MMM Tools and the Bible Gateway module that shows a Bible verse stretches out too far toward the center and covers up another module.
      The MMM Tools is set for top left, but it does not appear flush top left, it is closer to the clock module that is top center. How can I move MMM Tools more to the left? Or how can I make modules in general more flushed to the edge of the screen?
      The Bible Gateway module is set for bottom right and runs into the default news module set for bottom center position.
      I am new to the Magic Mirror so any help would be appreciated !
        sdetweil @Matthewlawson3
        @matthewlawson3 see how to use developers window
        https://forum.magicmirror.builders/topic/14782/make-a-remove-header-space-or-overlap-two-modules/2
          Matthewlawson3 @sdetweil
          @sdetweil okay I’ve read through some of what you posted. So I’m trying to get to the developer window to remove or modify certain regions on screen?
            @matthewlawson3 to find them, understand what is where.
            and y can copy main.css to custom css and give every region a different background color
            • BKeyportB Offline
              BKeyport Module Developer @Matthewlawson3
              If you wanna use the entire screen - in custom.css add:
              /* Use the entire screen */
              body {
              	margin: 0px;
              	height: 100vh;
              	width: 100vw;
              Don’t copy main.css into custom and start there - it’s a bad idea - just fiddle with the tags you wanna adjust. The mirror loads main.css, then every module’s CSS file, then custom.css and css will add your rules to the tag.
                sdetweil @BKeyport
                @bkeyport make sure if u change body like that, to fix the fullscreen definition which does a negative value to reverse the margin value coded in body.
                also, copying main was because we recommend NOT changing values there
                  @sdetweil okay. I’ve never modified anything CSS. Sounds like I am modifying code like that that is used for a webpage. A few questions…
                  Where is the main.css and custom.css located?
                  You are saying make a copy of the original main.css and I then modify the original main.css? I assume if something goes wrong that I can then copy back in place the copy of the original main.css to get everything back to normal.
                  What do I use custom.css for?
                  Thanks and forgive my ignorance on this!
                  S 3 Replies Last reply Reply Quote 0
                    @matthewlawson3 the css files are in the MagicMirror/css folder
                    MagicMirror is indeed a webpage, called a Single Page Application
                    because CSS supports overriding (replacing) styles previously defined
                    the order of processsing is
                    main.css
                    any module provided classes/styles, thru the getStyles() method
                    custom.css
                    this way custom.css can change anything defined before
                      @matthewlawson3 I was suggesting NEVER to modify main.css
                      so, if u follow that rule, you need custom.css to contain what is in main.css for testing
                        @matthewlawson3 see this topic
                        https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works?_=1616334901530
                          @sdetweil so I just copy the contents of main.css into a new file called custom.css? Then I modify custom.css and that should show when I run the MM? Or does that custom.css have to be renamed to main.css and the original main.css renamed to something else while testing?
                            @matthewlawson3 do this
                            cd ~/MagicMirror/css
                            cp main.css custom.css
                            edit custom.css and change
                            body {
                              margin: 60px;
                              position: absolute;
                              height: calc(100% - 120px);
                              width: calc(100% - 120px);
                              background: green;                                     <- this line
                              color: #aaa;
                              font-family: "Roboto Condensed", sans-serif;
                              font-weight: 400;
                              font-size: 2em;
                              line-height: 1.5em;
                              -webkit-font-smoothing: antialiased;
                            start mm
                            and u should see this
                            now you can see the border around the main area, where all the modules are placed
                              @Matthewlawson3
                              and if u set the background-color for date, time, and calendar
                              .calendar {
                              	background-color: blue;
                              .date {
                              	background-color: red;
                              .time {
                              	background-color: pink;
                              you’ll see this
                                @sdetweil Thank you. So when I can see the borders, I would assume I have to adjust the border size and make it smaller?
                                Below are some pictures of the MMM Tools issue and the BibleGateway issue where they are invading the space of the other modules. I need MMM Tools to fill that gap on the left and the BibleGateway module to get back to the right side.
                                alt text
                                alt text
                                  @matthewlawson3 u need to use the vertical page , sun over the mountains to upload a picture (third from right on desktop browser)
                                    Matthewlawson3
                                    @sdetweil Sorry. I have the green background and can see the border btw. Pictures are below of what it looks like normally. The MMM Tools is module is set for top left position and the calendar is too. The Bible module is set for bottom right position.
                                      @matthewlawson3 would be better if u backed up a little got the whole screen as one image… we can zoom in on the pic…
                                      what is that stomping all over the date?
                                        @sdetweil ahh that is MMM Tools. Since MMM Tools and the calendar are in the top left position this is how they end up. I like the calendar where it is. But the MMM Tools is pushed over to the right in this set up. Without the calendar, MMM Tools moves back to the left and out of the way.
                                          @matthewlawson3
                                          yeh, MMM-Tools looks like it has some css problems…
                                            @sdetweil Anything you can recommend for me to get it to behave? Something I could do in the custom.css?
