    Calendar - only all day events showing - moment timezone issue
    11 Posts 3 Posters 4.3k Views 3 Watching
      MagicInMe
      In my magic-mirror I am using the default calendar module and am connected to a microsoft (Outlook.com) calendar. It is only showing events from a birthday calendar (all-day events). It appears as though moment-timezone is struggling to parse the timezone information from the event. Any ideas as to what might be the problem? The log has a million entries like the one below:
      event={“type”:“VEVENT”,“params”:[],“uid”:“[REMOVED]”,“summary”:“[REMOVED]”,“start”:“2021-07-12T14:00:00.000Z”,“datetype”:“date-time”,“end”:“2021-07-12T15:00:00.000Z”,“class”:“PUBLIC”,“priority”:“5”,“dtstamp”:“2021-03-26T00:58:12.000Z”,“transparency”:“OPAQUE”,“status”:“CONFIRMED”,“sequence”:“0”,“location”:“”,“MICROSOFT-CDO-APPT-SEQUENCE”:“0”,“MICROSOFT-CDO-BUSYSTATUS”:“BUSY”,“MICROSOFT-CDO-INTENDEDSTATUS”:“BUSY”,“MICROSOFT-CDO-ALLDAYEVENT”:“FALSE”,“MICROSOFT-CDO-IMPORTANCE”:“1”,“MICROSOFT-CDO-INSTTYPE”:“0”,“MICROSOFT-DONOTFORWARDMEETING”:“FALSE”,“MICROSOFT-DISALLOW-COUNTER”:“FALSE”}
      [25.03.2021 20:59.47.298] [DEBUG] start=Mon Jul 12 2021 10:00:00 GMT-0400 (Eastern Daylight Time) end=Mon Jul 12 2021 11:00:00 GMT-0400 (Eastern Daylight Time)
      [25.03.2021 20:59.47.304] [DEBUG] initial tz=Customized Time Zone
      [25.03.2021 20:59.47.312] [DEBUG] corrected TZ=null
      [25.03.2021 20:59.47.326] [DEBUG] corrected tz=Customized Time Zone
      [25.03.2021 20:59.47.333] [DEBUG] start date/time=Mon Jul 12 2021 10:00:00 GMT-0400 (Eastern Daylight Time)
      [25.03.2021 20:59.47.341] [ERROR] Moment Timezone has no data for Customized Time Zone. See http://momentjs.com/timezone/docs/#/data-loading/.
      [25.03.2021 20:59.47.351] [DEBUG] start offset=0
      [25.03.2021 20:59.47.364] [ERROR] Moment Timezone has no data for Customized Time Zone. See http://momentjs.com/timezone/docs/#/data-loading/.
      [25.03.2021 20:59.47.369] [DEBUG] start date/time w tz =Mon Jul 12 2021 10:00:00 GMT-0400 (Eastern Daylight Time)
      [25.03.2021 20:59.47.382] [ERROR] Moment Timezone has no data for Customized Time Zone. See http://momentjs.com/timezone/docs/#/data-loading/.
      [25.03.2021 20:59.47.393] [DEBUG] event date=Mon Jul 12 2021 10:00:00 GMT-0400 (Eastern Daylight Time)
      [25.03.2021 20:59.47.400] [DEBUG] event offset=0 hour=14 event date=Mon Jul 12 2021 10:00:00 GMT-0400 (Eastern Daylight Time)
      [25.03.2021 20:59.47.407] [DEBUG] adjustHours=0
      [25.03.2021 20:59.47.424] [DEBUG] have entries
      [25.03.2021 20:59.47.431] [DEBUG]
        sdetweil @MagicInMe
        @magicinme yes, fun times. Microsoft has lots of non-standard timezone definitions.
        I just put fixes into the ical parser we use.
        hopefully they will be published soon do we can update the dependency list.
          MagicInMe @sdetweil
          @sdetweil Great, thank you! What do you think the ETA would be? Just for my own sanity :P
            sdetweil @MagicInMe
            @magicinme I don’t know. I hope soon so we can include it in the next release on April 1st
              MagicInMe @sdetweil
              @sdetweil perfect, thanks a bunch!
                sdetweil @MagicInMe
                @magicinme the fix did NOT make 2.15, as the repo published the fixes JUST last night
                if u want to test/run with the new code do
                npm install node-ical
                restart MM
                same for 2.14 or 2.15
                  MagicInMe @sdetweil
                  @sdetweil Thank you! I am running it now, I’m still getting
                  [12.04.2021 08:39.20.358] [ERROR] Moment Timezone has no data for Customized Time Zone. See http://momentjs.com/timezone/docs/#/data-loading/.
                  but it appears as though there are fewer errors and the module does seem to be displaying my events. Perhaps I have some buggy iCal events in there. If I get a chance to dive in more, I’ll see what I can update.
                    sdetweil @MagicInMe
                    @magicinme can u send me your ics file. I thought we put fixes in 2.15 for this
                    my email is the same user ID at gmail
                    oh, wait, the fixes are in node-ical
                    do
                    the restart mm
                      MagicInMe
                      It appears as though the issue arises when the calendar has custom (non-standard) timezones. node-ical parses the file properly however there is no code to digest the parsed VTIMEZONE entries and apply them to referencing events. Looking at this VTIMEZONE entry, it seems rather hack-y so it probably is not worth it to parse. I notice that all of the weird entries are originate from an iPhone.
                      Here’s an example ical file of an offending text:
                      BEGIN:VCALENDAR
                      PRODID:-//Microsoft Corporation//Outlook 16.0 MIMEDIR//EN
                      VERSION:2.0
                      METHOD:PUBLISH
                      X-MS-OLK-FORCEINSPECTOROPEN:TRUE
                      BEGIN:VTIMEZONE
                      TZID:Customized Time Zone
                      BEGIN:STANDARD
                      DTSTART:16011104T020000
                      RRULE:FREQ=YEARLY;BYDAY=1SU;BYMONTH=11
                      TZOFFSETFROM:-0400
                      TZOFFSETTO:-0500
                      END:STANDARD
                      BEGIN:DAYLIGHT
                      DTSTART:16010311T020000
                      RRULE:FREQ=YEARLY;BYDAY=2SU;BYMONTH=3
                      TZOFFSETFROM:-0500
                      TZOFFSETTO:-0400
                      END:DAYLIGHT
                      END:VTIMEZONE
                      BEGIN:VEVENT
                      CLASS:PUBLIC
                      CREATED:20210906T061657Z
                      DTEND;TZID="Customized Time Zone":20210605T110000
                      DTSTAMP:20210906T061658Z
                      DTSTART;TZID="Customized Time Zone":20210605T100000
                      LAST-MODIFIED:20210906T061657Z
                      PRIORITY:5
                      SEQUENCE:0
                      SUMMARY;LANGUAGE=en-us:Top secret stuff
                      TRANSP:OPAQUE
                      UID:04000000[.....]
                      X-MICROSOFT-CDO-BUSYSTATUS:BUSY
                      X-MICROSOFT-CDO-IMPORTANCE:1
                      END:VEVENT
                      END:VCALENDAR
                        sdetweil @MagicInMe
                        @magicinme none of the libraries digest the tz definitions. mm doesn’t either.
                          sdetweil @MagicInMe
                          @magicinme those are Microsoft-isms.
                          I put code in node-ical and mm to handle, but the definitions aren’t parsed.
                          the supporting nodejs libs don’t understand custom timezones, so I convert to iana tz.
