Calendar - only all day events showing - moment timezone issue
11 Posts 3 Posters 3.4k Views 3 Watching
    MagicInMe
    In my magic-mirror I am using the default calendar module and am connected to a microsoft (Outlook.com) calendar. It is only showing events from a birthday calendar (all-day events). It appears as though moment-timezone is struggling to parse the timezone information from the event. Any ideas as to what might be the problem? The log has a million entries like the one below:
    event={“type”:“VEVENT”,“params”:[],“uid”:“[REMOVED]”,“summary”:“[REMOVED]”,“start”:“2021-07-12T14:00:00.000Z”,“datetype”:“date-time”,“end”:“2021-07-12T15:00:00.000Z”,“class”:“PUBLIC”,“priority”:“5”,“dtstamp”:“2021-03-26T00:58:12.000Z”,“transparency”:“OPAQUE”,“status”:“CONFIRMED”,“sequence”:“0”,“location”:“”,“MICROSOFT-CDO-APPT-SEQUENCE”:“0”,“MICROSOFT-CDO-BUSYSTATUS”:“BUSY”,“MICROSOFT-CDO-INTENDEDSTATUS”:“BUSY”,“MICROSOFT-CDO-ALLDAYEVENT”:“FALSE”,“MICROSOFT-CDO-IMPORTANCE”:“1”,“MICROSOFT-CDO-INSTTYPE”:“0”,“MICROSOFT-DONOTFORWARDMEETING”:“FALSE”,“MICROSOFT-DISALLOW-COUNTER”:“FALSE”}
    [25.03.2021 20:59.47.298] [DEBUG] start=Mon Jul 12 2021 10:00:00 GMT-0400 (Eastern Daylight Time) end=Mon Jul 12 2021 11:00:00 GMT-0400 (Eastern Daylight Time)
    [25.03.2021 20:59.47.304] [DEBUG] initial tz=Customized Time Zone
    [25.03.2021 20:59.47.312] [DEBUG] corrected TZ=null
    [25.03.2021 20:59.47.326] [DEBUG] corrected tz=Customized Time Zone
    [25.03.2021 20:59.47.333] [DEBUG] start date/time=Mon Jul 12 2021 10:00:00 GMT-0400 (Eastern Daylight Time)
    [25.03.2021 20:59.47.341] [ERROR] Moment Timezone has no data for Customized Time Zone. See http://momentjs.com/timezone/docs/#/data-loading/.
    [25.03.2021 20:59.47.351] [DEBUG] start offset=0
    [25.03.2021 20:59.47.364] [ERROR] Moment Timezone has no data for Customized Time Zone. See http://momentjs.com/timezone/docs/#/data-loading/.
    [25.03.2021 20:59.47.369] [DEBUG] start date/time w tz =Mon Jul 12 2021 10:00:00 GMT-0400 (Eastern Daylight Time)
    [25.03.2021 20:59.47.382] [ERROR] Moment Timezone has no data for Customized Time Zone. See http://momentjs.com/timezone/docs/#/data-loading/.
    [25.03.2021 20:59.47.393] [DEBUG] event date=Mon Jul 12 2021 10:00:00 GMT-0400 (Eastern Daylight Time)
    [25.03.2021 20:59.47.400] [DEBUG] event offset=0 hour=14 event date=Mon Jul 12 2021 10:00:00 GMT-0400 (Eastern Daylight Time)
    [25.03.2021 20:59.47.407] [DEBUG] adjustHours=0
    [25.03.2021 20:59.47.424] [DEBUG] have entries
    [25.03.2021 20:59.47.431] [DEBUG]
    S 1 Reply Last reply Mar 26, 2021, 1:45 AM Reply Quote 0
      sdetweil @MagicInMe
      @magicinme yes, fun times. Microsoft has lots of non-standard timezone definitions.
      I just put fixes into the ical parser we use.
      hopefully they will be published soon do we can update the dependency list.
      M 1 Reply Last reply Mar 26, 2021, 4:03 AM Reply Quote 0
        MagicInMe @sdetweil
        @sdetweil Great, thank you! What do you think the ETA would be? Just for my own sanity :P
        S 1 Reply Last reply Mar 26, 2021, 11:49 AM Reply Quote 0
          sdetweil @MagicInMe
          @magicinme I don’t know. I hope soon so we can include it in the next release on April 1st
          M 1 Reply Last reply Mar 26, 2021, 12:04 PM Reply Quote 0
            MagicInMe @sdetweil
            @sdetweil perfect, thanks a bunch!
            S 1 Reply Last reply Apr 1, 2021, 12:38 PM Reply Quote 0
              sdetweil @MagicInMe
              @magicinme the fix did NOT make 2.15, as the repo published the fixes JUST last night
              if u want to test/run with the new code do
              npm install node-ical
              restart MM
              same for 2.14 or 2.15
              M 1 Reply Last reply Apr 12, 2021, 12:44 PM Reply Quote 0
                MagicInMe @sdetweil
                @sdetweil Thank you! I am running it now, I’m still getting
                [12.04.2021 08:39.20.358] [ERROR] Moment Timezone has no data for Customized Time Zone. See http://momentjs.com/timezone/docs/#/data-loading/.
                but it appears as though there are fewer errors and the module does seem to be displaying my events. Perhaps I have some buggy iCal events in there. If I get a chance to dive in more, I’ll see what I can update.
                S 1 Reply Last reply Apr 12, 2021, 12:54 PM Reply Quote 0
                  sdetweil @MagicInMe
                  @magicinme can u send me your ics file. I thought we put fixes in 2.15 for this
                  my email is the same user ID at gmail
                  oh, wait, the fixes are in node-ical
                  do
                  the restart mm
                    MagicInMe
                    It appears as though the issue arises when the calendar has custom (non-standard) timezones. node-ical parses the file properly however there is no code to digest the parsed VTIMEZONE entries and apply them to referencing events. Looking at this VTIMEZONE entry, it seems rather hack-y so it probably is not worth it to parse. I notice that all of the weird entries are originate from an iPhone.
                    Here’s an example ical file of an offending text:
                    BEGIN:VCALENDAR
                    PRODID:-//Microsoft Corporation//Outlook 16.0 MIMEDIR//EN
                    VERSION:2.0
                    METHOD:PUBLISH
                    X-MS-OLK-FORCEINSPECTOROPEN:TRUE
                    BEGIN:VTIMEZONE
                    TZID:Customized Time Zone
                    BEGIN:STANDARD
                    DTSTART:16011104T020000
                    RRULE:FREQ=YEARLY;BYDAY=1SU;BYMONTH=11
                    TZOFFSETFROM:-0400
                    TZOFFSETTO:-0500
                    END:STANDARD
                    BEGIN:DAYLIGHT
                    DTSTART:16010311T020000
                    RRULE:FREQ=YEARLY;BYDAY=2SU;BYMONTH=3
                    TZOFFSETFROM:-0500
                    TZOFFSETTO:-0400
                    END:DAYLIGHT
                    END:VTIMEZONE
                    BEGIN:VEVENT
                    CLASS:PUBLIC
                    CREATED:20210906T061657Z
                    DTEND;TZID="Customized Time Zone":20210605T110000
                    DTSTAMP:20210906T061658Z
                    DTSTART;TZID="Customized Time Zone":20210605T100000
                    LAST-MODIFIED:20210906T061657Z
                    PRIORITY:5
                    SEQUENCE:0
                    SUMMARY;LANGUAGE=en-us:Top secret stuff
                    TRANSP:OPAQUE
                    UID:04000000[.....]
                    X-MICROSOFT-CDO-BUSYSTATUS:BUSY
                    X-MICROSOFT-CDO-IMPORTANCE:1
                    END:VEVENT
                    END:VCALENDAR
                    S 2 Replies Last reply Sep 6, 2021, 1:14 PM Reply Quote 0
                      sdetweil @MagicInMe
                      @magicinme none of the libraries digest the tz definitions. mm doesn’t either.
