weather module just shows loading?
I just noticed that the ‘currentweather’ module I’ve set up a long time ago, is now deprecated, and I should use weather instead.
So I tried setting it up, but it just shows ‘loading’.
The config I’ve built looks like this:{ module: 'weather', position: 'top_right', classes: 'day_schedule', config: { weatherProvider: 'openweathermap', type: "current", units: 'metric', timeFormat: '24', decimalSymbol: ',', initialLoadDelay: '0', onlyTemp: 'true', location: 'Greve', locationID: '2621215', appid: 'xxx' } },I then tried stripping it to the example:
{ module: "weather", position: "top_right", config: { // See 'Configuration options' for more information. type: 'current' } },Still just shows loading…
Are your single quotes ’ just an accident in your examples?
{ module: "currentweather", position: "top_right", header: "my header", config: { location: "my village", // locationID: "numbers", //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city appid: "wholelottanumbers", appendLocationNameToHeader: false, degreeLabel: true, useBeaufort: false, useKMPHwind: true, showHumidity: true } },Hope this helps.
@scumbelly single or double doesn’t matter as long as they are the same
please use code markers around config info.
there is a third kinds of quote mark used by the forum without code blocks. they are word processing type, they are curved, both single and double. they are bad." and ’
notice the difference" and ' -
O.K.
and… onlyTemp: ‘true’, would not have any quotes.
@scumbelly right…
general config.js rules
thing to the left of colon (:) does not need quotes
if the thing to the right of colon is a number or true/false,
should NOT have quotes,
otherwise the thing to the right needs quotes.
single or double doesn’t matter, as long as both ends are the same -
Thanks, I always thought I needed double quotes.
Ok, I found out what was wrong, despite the confusion with the ’ or " use.
It’s the appid, it’s called apiKey in the weather module.
So after changing that (and also changing all ’ to " in the config), removing quotes around numbers, only have the locationID instead of both location and locationID and other cleanup stuff, it is shows properly :-)So I replaced both my currentweather and YrThen modules with two weather modules:
{ module: "weather", position: "top_right", classes: "day_schedule", config: { weatherProvider: "openweathermap", type: "current", units: "metric", timeFormat: 24, decimalSymbol: ",", initialLoadDelay: 0, onlyTemp: false, locationID: 2621215, apiKey: "xxx" } }, { module: "weather", position: "top_right", classes: "day_schedule", config: { weatherProvider: "openweathermap", type: "forecast", units: "metric", timeFormat: 24, decimalSymbol: ",", initialLoadDelay: 0, onlyTemp: true, maxNumberOfDays: 7, colored: true, appendLocationNameToHeader: false, locationID: 2621215, apiKey: "xxx" } },Looks very nice indeed
