    Error on Start (fresh install) - Electron Illegal Access
    11 Posts 2 Posters 2.5k Views 2 Watching
    • F Offline
      frosty_snow
      Hi all,
      Trying to get my class project started, but unable to get MagicMirror running on my monitor. When I attempt to start I keep getting:
      pi@raspberrypi:~/MagicMirror $ npm run start
      > > magicmirror@2.15.0 start
      > > node_modules/.bin/electron js/electron.js
      > [09.04.2021 14:35.19.085] [LOG]   Starting MagicMirror: v2.15.0
      > [09.04.2021 14:35.19.091] [LOG]   Loading config ...
      > [09.04.2021 14:35.19.098] [LOG]   Loading module helpers ...
      > [09.04.2021 14:35.19.100] [LOG]   No helper found for module: alert.
      > [09.04.2021 14:35.19.264] [LOG]   Initializing new module helper ...
      > [09.04.2021 14:35.19.265] [LOG]   Module helper loaded: updatenotification
      > [09.04.2021 14:35.19.266] [LOG]   No helper found for module: clock.
      > [09.04.2021 14:35.19.770] [LOG]   Initializing new module helper ...
      > [09.04.2021 14:35.19.771] [LOG]   Module helper loaded: calendar
      > [09.04.2021 14:35.19.772] [LOG]   No helper found for module: compliments.
      > [09.04.2021 14:35.19.772] [LOG]   No helper found for module: weather.
      > [09.04.2021 14:35.19.795] [LOG]   Initializing new module helper ...
      > [09.04.2021 14:35.19.796] [LOG]   Module helper loaded: newsfeed
      > [09.04.2021 14:35.19.796] [LOG]   All module helpers loaded.
      > [09.04.2021 14:35.19.880] [LOG]   Starting server on port 8080 ...
      > [09.04.2021 14:35.19.894] [LOG]   Server started ...
      > [09.04.2021 14:35.19.895] [LOG]   Connecting socket for: updatenotification
      > [09.04.2021 14:35.19.896] [LOG]   Connecting socket for: calendar
      > [09.04.2021 14:35.19.897] [LOG]   Starting node helper for: calendar
      > [09.04.2021 14:35.19.898] [LOG]   Connecting socket for: newsfeed
      > [09.04.2021 14:35.19.899] [LOG]   Starting node helper for: newsfeed
      > [09.04.2021 14:35.19.900] [LOG]   Sockets connected & modules started ...
      > undefined:0
      > illegal access
      > (Use `electron --trace-uncaught ...` to show where the exception was thrown)
      I’m afraid I do not know much about electron and having trouble diagnosing what is going wrong.
      I began with doing the correction indicated here regarding common installation issues: https://docs.magicmirror.builders/getting-started/installation.html#manual-installation
      I also tried a few suggestions for other issues that seemed possibly similar such as delete the node_modules/electron folder and rerun npm install in /MagicMirror directory
      Also tried npm rebuild in the MagicMirror directory and tried to start again and that was unsuccessful.
      Any advice? Struggling to get the basics up and running so I can jump full into my project and after about an hour of troubleshooting unsure of what to try next and any help is appreciated!
        sdetweil @frosty_snow
        @frosty_snow can u try running the automated install script
        see here
        remove or rename the MagicMirror folder to some other name
        the script assumes starting fresh
        • F Offline
          frosty_snow @sdetweil
          Thank you! I think that solved that problem.
          Should the monitor that is connected (its connected via a microHDMI to HDMI and then an HDMI to DisplayPort adapter at the other end) automatically display once I’ve run pm2 start MagicMirror? Or do I need to take an additional step?
          It indicates process successfully started, however the monitor doesn’t show anything.
          I should note we’ve only ever ssh’d into the Pi from our desktops and I’ve never used a GUI connected to the Pi before, so very possible I’m not doing something correctly in that regard.
            @frosty_snow it should show, the startup sets the linux xwindows DISPLAY=:0
            unless there is another problem…
            do
            pm2 logs --lines=50
            pm2 status to show whats running
            pm2 stop all
            pm2 --help
            for more options
            • F Offline
              Ok when I do pm2 status i do see that the status is “online” after I do the pm2 start MagicMirror. However yes it appears there is another issue, as my display simply remains blank (I’ve 3 screens, 2 connected to my desktop with the 3rd connected to the Rpi4).
              The log files show the following errors, which would seem its related to this line 102. Is it possible I need to edit this?
              /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
              0|MagicMir | ./run-start.sh: line 102:   841 Killed                  node server        only
              0|MagicMir | npm ERR! code ELIFECYCLE
              0|MagicMir | npm ERR! errno 137
              0|MagicMir | npm ERR! magicmirror@2.15.0 start: `./run-start.sh $1`
              0|MagicMir | npm ERR! Exit status 137
              0|MagicMir | npm ERR! Failed at the magicmirror@2.15.0 start script.
              0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely a        dditional logging output above.
              0|MagicMir |
              0|MagicMir | npm ERR! A complete log of this run can be found in:
              0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2021-04-09T20_25_23_729Z-debug.log
              0|MagicMir | ./run-start.sh: line 102:  2087 Killed                  node server        only
              0|MagicMir |
              0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2021-04-09T20_27_20_593Z-debug.log
              0|MagicMir | ./run-start.sh: line 102:   814 Killed                  node server        only
              0|MagicMir |
              0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2021-04-09T20_53_27_407Z-debug.log
                @frosty_snow ok, that is my run-start.sh script which is put in in the case where electron won’t run …
                BUT it should start chromium-browser
                can u do
                which chromium
                and
                which cromium-browser
                on a terminal window on the pi (or ssh session to the pi)
                because electron won’t run, we launch MM in server mode
                and then launch chrome over it…
                i had a case where the previous server mode was still running, and so I don’t have to tell u how to correct that, I kill it…
                pm2 job is to keep MM running… so, when the script ends, pm2 restarts it…
                over and over…
                oh by the way… the column on the pm2 status that looks like a circle with an arrow tip is the number of restarts… for your case at the moment, it should be going up
                • F Offline
                  currently im only at 1 but it said 2 before i rebooted my pi
                  The below is the result of those cmds in the ssh session into the pi on my desktop
                  pi@raspberrypi:~ $ which chromium
                  pi@raspberrypi:~ $ which chromium-browser
                  /usr/bin/chromium-browser
                  pi@raspberrypi:~ $
                  I’ve rebooted the pi before trying to start MM up again
                    @frosty_snow ok, stop mm
                    pm2 stop 0
                    then do
                    bash -x ./run-start.sh  >somefile 2>&1
                    wait 10 seconds, then ctrl-c
                    and post or send me somefile
                    my email is the same userid at gmail.com
                    S F 2 Replies Last reply Reply Quote 0
                      @frosty_snow correction , see I added a little on to the bash -x line to capture the bash output
                      sorry try again
                      • F Offline
                        I’d like to thank you so much for taking the time on this. I’ve figured out that it is a hardware issue. I switched up to a different monitor that is not display port and the MM is working correctly. I don’t know if its the Displayport that is the problem or not but I can use my other monitor for the actual MM build and just use this displayPort monitor as my secondary “reading” monitor.
                        Hope you have a lovely weekend and thank you again for working with me.
                          @frosty_snow cool…
