    Error on Start (fresh install) - Electron Illegal Access
    11 Posts 2 Posters 3.2k Views 2 Watching
      sdetweil @frosty_snow
      @frosty_snow can u try running the automated install script
      see here
      remove or rename the MagicMirror folder to some other name
      the script assumes starting fresh
      F 1 Reply Last reply
      • F
        frosty_snow @sdetweil
        Thank you! I think that solved that problem.
        Should the monitor that is connected (its connected via a microHDMI to HDMI and then an HDMI to DisplayPort adapter at the other end) automatically display once I’ve run pm2 start MagicMirror? Or do I need to take an additional step?
        It indicates process successfully started, however the monitor doesn’t show anything.
        I should note we’ve only ever ssh’d into the Pi from our desktops and I’ve never used a GUI connected to the Pi before, so very possible I’m not doing something correctly in that regard.
          @frosty_snow it should show, the startup sets the linux xwindows DISPLAY=:0
          unless there is another problem…
          do
          pm2 logs --lines=50
          pm2 status to show whats running
          pm2 stop all
          pm2 --help
          for more options
          • F
            Ok when I do pm2 status i do see that the status is “online” after I do the pm2 start MagicMirror. However yes it appears there is another issue, as my display simply remains blank (I’ve 3 screens, 2 connected to my desktop with the 3rd connected to the Rpi4).
            The log files show the following errors, which would seem its related to this line 102. Is it possible I need to edit this?
            /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
            0|MagicMir | ./run-start.sh: line 102:   841 Killed                  node server        only
            0|MagicMir | npm ERR! code ELIFECYCLE
            0|MagicMir | npm ERR! errno 137
            0|MagicMir | npm ERR! magicmirror@2.15.0 start: `./run-start.sh $1`
            0|MagicMir | npm ERR! Exit status 137
            0|MagicMir | npm ERR! Failed at the magicmirror@2.15.0 start script.
            0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely a        dditional logging output above.
            0|MagicMir |
            0|MagicMir | npm ERR! A complete log of this run can be found in:
            0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2021-04-09T20_25_23_729Z-debug.log
            0|MagicMir | ./run-start.sh: line 102:  2087 Killed                  node server        only
            0|MagicMir |
            0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2021-04-09T20_27_20_593Z-debug.log
            0|MagicMir | ./run-start.sh: line 102:   814 Killed                  node server        only
            0|MagicMir |
            0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2021-04-09T20_53_27_407Z-debug.log
              @frosty_snow ok, that is my run-start.sh script which is put in in the case where electron won’t run …
              BUT it should start chromium-browser
              can u do
              which chromium
              and
              which cromium-browser
              on a terminal window on the pi (or ssh session to the pi)
              because electron won’t run, we launch MM in server mode
              and then launch chrome over it…
              i had a case where the previous server mode was still running, and so I don’t have to tell u how to correct that, I kill it…
              pm2 job is to keep MM running… so, when the script ends, pm2 restarts it…
              over and over…
              oh by the way… the column on the pm2 status that looks like a circle with an arrow tip is the number of restarts… for your case at the moment, it should be going up
              • F
                currently im only at 1 but it said 2 before i rebooted my pi
                The below is the result of those cmds in the ssh session into the pi on my desktop
                pi@raspberrypi:~ $ which chromium
                pi@raspberrypi:~ $ which chromium-browser
                /usr/bin/chromium-browser
                pi@raspberrypi:~ $
                I’ve rebooted the pi before trying to start MM up again
                  @frosty_snow ok, stop mm
                  pm2 stop 0
                  then do
                  bash -x ./run-start.sh  >somefile 2>&1
                  wait 10 seconds, then ctrl-c
                  and post or send me somefile
                  my email is the same userid at gmail.com
                  S F 2 Replies Last reply
                    @frosty_snow correction , see I added a little on to the bash -x line to capture the bash output
                    sorry try again
                    • F
                      I’d like to thank you so much for taking the time on this. I’ve figured out that it is a hardware issue. I switched up to a different monitor that is not display port and the MM is working correctly. I don’t know if its the Displayport that is the problem or not but I can use my other monitor for the actual MM build and just use this displayPort monitor as my secondary “reading” monitor.
                      Hope you have a lovely weekend and thank you again for working with me.
                        @frosty_snow cool…
