    SD Card - no Space
    15 Posts 4 Posters 3.9k Views 4 Watching
      c1olli
      In the last months the SD card (32GB) of the MM were after 2 weeks full of data.
      I tried 3 times to find the problem, but at least I made it completly new.
      Today the SD card was full again and I found out, that the MagicMirror-error.log was about 24GB big.
      So I deleted it and the system is working again.
      But why was it so big? Because of the amount of data I could not open ist.
        sdetweil @c1olli
        @c1olli edit the config.js and remove debug from the logLevel:[] list
        like this (remove “DEBUG”)
        logLevel: ["INFO", "LOG", "WARN", "ERROR"],
        supposed to be off by default…
        then pm2 flush
        then start MM again
        pm2 restart 0
        C G 2 Replies Last reply Reply Quote 0
          c1olli @sdetweil
          @sdetweil said in SD Card - no Space:
          logLevel: [“INFO”, “LOG”, “WARN”, “ERROR”],
          Thanks,
          the loglevel was complete missing in the config.js, but the systems wrote logs.
          Now I added it like in your post. Let’s see what will happen.
          Is it possible to turn the logs out ? Maybe with
          loglevel: [ ], ?
            sdetweil @c1olli
            @c1olli nothing logs (at this time) except calendar for DEBUG
              c1olli @sdetweil
              @sdetweil It does’nt matter what I do - the log expanses.
              So I started now a cronjob with a daily flush of the log data.
                sdetweil @c1olli
                @c1olli what is in the log?
                  c1olli @sdetweil
                  That is the log from about 2 hours - more than 1 million lines.
                  And always the same.
                    sdetweil @c1olli
                    @c1olli you have a failing module.
                    MMM-Fronius
                    you should disable it until u can resolve the problem
                      c1olli @sdetweil
                      That solved the problem. So I will fetch the Fronius Data via MMM-ioBroker in future.
                      A 1 Reply Last reply Reply Quote 1
                      • G Offline
                        George @sdetweil
                        @sdetweil , hi, I think I have the same problem with the card, the mirror starts very slowly, “sudo reboot” does not always work. Please, can you explain me step by step how to remove debug?
