    SD Card - no Space
    15 Posts 4 Posters 6.0k Views 4 Watching
      sdetweil @c1olli
      @c1olli what is in the log?
        c1olli @sdetweil
        That is the log from about 2 hours - more than 1 million lines.
        And always the same.
          sdetweil @c1olli
          @c1olli you have a failing module.
          MMM-Fronius
          you should disable it until u can resolve the problem
            c1olli @sdetweil
            That solved the problem. So I will fetch the Fronius Data via MMM-ioBroker in future.
            A 1 Reply Last reply Reply Quote 1
            • G Offline
              George @sdetweil
              @sdetweil , hi, I think I have the same problem with the card, the mirror starts very slowly, “sudo reboot” does not always work. Please, can you explain me step by step how to remove debug?
                sdetweil @George
                @george https://forum.magicmirror.builders/topic/14915/sd-card-no-space/2
                • G Offline
                  George @sdetweil
                  @sdetweil , thanks, i already read this post but i don’t know how to edit config.js list. How do I get in there? :(
                    sdetweil @George
                    @george how do you edit it to add a module? same way
                    read the link in my signature, How to add Modules
                      avolaid @c1olli
                      @c1olli said in SD Card - no Space:
                      MMM-ioBroker
                      How did you got the Fronius fork with the MMM-ioBroker?
                        c1olli @avolaid
                        @avolaid said in SD Card - no Space:
                        MMM-fronius ist sending the data direktly to the Mirror.
                        MMM-ioBroker sends my ioBroker data to the Mirror and has a adaptor to fronius.
                        So both adaptors are working not together.
