    Calendar Date Formats Not Working.
    7 Posts 3 Posters 1.0k Views 2 Watching
      A Former User
      Module = Calendar
      Issue = Trying to get the date format is DD/MM/YYYY currently in default even when specified not to. Don’t know if I am incorrectly specifying.
      Current Module Config = {
      module: “calendar”,
      header: “My Calendar”,
      position: “top_left”,
      maximumEntries: “6”,
      maximumNumberOfDays: “7”,
      wrapEvents: “true”,
      maxTitleLines: “2”,
      fadePoint: “1”,
      dateFormat: “Do MMM”,
      hideTime: “true”,
      fetchInterval: “60000”,
      symbol: “calendar-check”,
      url: “webcal://p39-caldav.icloud.com/published/2/MTExNjgwMjM2NTExMTE2OIZFb1PsCmMo3ecwDd6H7xOGtd_rniDwbBvisBnUUbTo”
      url: “webcal://p39-caldav.icloud.com/published/2/MTExNjgwMjM2NTExMTE2OIZFb1PsCmMo3ecwDd6H7xPI-y3Ntq2MNAzfi5poNWuySmEYsiAGaraNGLnR7zZorrG5xXn8wrtERNCCDMDMxcw”
        sdetweil @Guest
        @jack_barnard must use tineFormat: ‘absolute’ to turn on those controls
          A Former User @sdetweil
          Thanks that has helped a bit but the date still won’t display in DD/MM/YYYY which should the value be for dateFormat: “”?
            sdetweil @Guest
            @jack_barnard https://devhints.io/moment
            https://docs.magicmirror.builders/modules/calendar.html
            there are also fullDayEventDateFormat
              Thanks for pointing me in the right direction but I don’t understand the moments formating for dates could you explain further on how to setup the correct format?
              TipponT 1 Reply Last reply Reply Quote 0
              • TipponT Offline
                Tippon @Guest
                @jack_barnard I’ve got mine setup like this:
                        timeFormat: 'absolute',
                        dateFormat: 'DD/MM/YYYY',
                        fullDayEventDateFormat: 'DD/MM/YYYY',
                Hope this helps :)
                Please forgive me if I'm slow to reply, I'm currently experiencing memory issues, and sometimes forget that I've asked a question >.<
                  A Former User @Tippon
                  @tippon
                  Thanks this now working perfectly.
