    default Weather, current with wethergov issues
    16 Posts 4 Posters 5.9k Views 4 Watching
    • L Offline
      linuxha @scumbelly
      @scumbelly
      Here’s the weather config section:
      	units:      "imperial", // global
      			module: "weather",
      			//position: "top_right",
      			position: "bottom_left",
      				type: "current",
      				weatherProvider: "weathergov", //Default value: openweathermap
      				//windUnits: "imperial", // this is messed up in the code
      				tempUnits: "imperial",
      				useBeaufort: false,
      				fade: false,
      				//apiBase: "https://api.weather.gov/points/",
      				//weatherEndpoint: "/forecast/hourly", // for current
      				lat:        40.25571,
      				lon:        -74.39416,
      I basically get this:
      chopped screen shot
        scumbelly @linuxha
        @linuxha
        This is what I am guessing is your weather.
          scumbelly @scumbelly
          @linuxha
          That’s odd. Your wind speed looks like it could be in meters/seconds but it should be about 3.3 @ 7 miles per hour. So, are you using the current weather module or the ‘new’ weather module?
          Cheers
          • L Offline
            linuxha @scumbelly
            @scumbelly , the new weather module, the old is call currentweather and weatherforecast. Those are commented out in my config.
              scumbelly @linuxha
              @linuxha
              With following set you should get correct weather… except wind chill.
              language: “en”,
              locale: “en-US”,
              logLevel: [“INFO”, “LOG”, “WARN”, “ERROR”], // Add “DEBUG” for even more logging
              timeFormat: 12,
              units: “imperial”,
              			type: "current",
              			degreeLabel: true,
              			showFeelsLike: false,
              			lat:        40.25571,
              			lon:        -74.39416,
              No matter what I tried Feels Like came up as 32degrees. The web site shows “wind chill” and openweathermap shows “feels like” and the current.njk translates “FEELS” - DEGREE. I’m scratching my head for now.
              Cheers.
                @linxha
                I captured an xml string from your location…
                <current_observation version=“1.0”
                xmlns:xsd=“http://www.w3.org/2001/XMLSchema”
                xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance”
                xsi:noNamespaceSchemaLocation=“http://www.weather.gov/view/current_observation.xsd”>
                NOAA’s National Weather Service
                <credit_URL>http://weather.gov/</credit_URL>
                http://weather.gov/images/xml_logo.gif
                NOAA's National Weather Service http://weather.gov 15 minutes after the hour 60 Belmar-Farmingdale, NJ KBLM 40.18333 -74.13333 Last Updated on Apr 14 2021, 12:56 pm EDT Wed, 14 Apr 2021 12:56:00 -0400 A Few Clouds 70.0 F (21.1 C) 70.0 21.1 39 from the West at 9.2 gusting to 17.3 MPH (8 gusting to 15 KT) West 270 9.2 17.3 8 15 1016.4 mb 1016.4 30.02 44.1 F (6.7 C) 44.1 6.7 10.00 http://forecast.weather.gov/images/wtf/small/ http://www.weather.gov/data/obhistory/KBLM.html few.png http://www.weather.gov/data/METAR/KBLM.1.txt http://weather.gov/disclaimer.html http://weather.gov/disclaimer.html http://weather.gov/notice.html
                … but I saw no ‘wind chill’ or ‘feels like’ information at the time I grabbed the file.
                I’ve gone about as far as I can. Hopefully someone can add more to this for you.
                Cheers.
                • L Offline
                  linuxha @scumbelly
                  @scumbelly , huge thanks for the help. What URL did you use to get the XML? For weather.gov, I’ve been seeing JSON.
                  I think I’ll toss in a few log statements and see what weather.gov code is using.
                    scumbelly @linuxha
                    @linuxha
                    https://w1.weather.gov/xml/current_obs/KBLM.xml
                    • L Offline
                      linuxha
                      I figured out the Feels like being 32F, it’s getting a null in the heat index from weather.gov. I’ve added code to check for null and use the currentWeather.temperature instead. I’ll send diffs later (where do I send them?) when I’ve finished with the windSpeed.
                      		if(currentWeatherData.heatIndex.value) {
                      			currentWeather.feelsLikeTemp = this.convertTemp(currentWeatherData.heatIndex.value);
                      		} else {
                      			// If null, set it to the current temperature
                      			currentWeather.feelsLikeTemp = currentWeather.temperature;
                      Sorry it took so long for me to figure out this env. I’m using the browser to debug now. I’ve not done this much. :-)
                      • L Offline
                        linuxha
                        Okay, I see the issue with windSpeed. The URL returns windSpeed in km_h-1 (k/h), the convertSpeed(metSec) function appears to be m/s. I’m not sure how to fix this for general use. I’ll try to fix it for my use first.
                          sdetweil @linuxha
                          @linuxha google search on conversion says divide the km/h by 3.6 to get m/s
                          • L Offline
                            linuxha @sdetweil
                            @sdetweil , thanks, I did find those but I’m also trying to figure out a way so when I change the code it doesn’t break the existing. I’m just giving it thought now.
                            To convert kph to mph: *0.621371. I 'm used to MPH and m/s or kph wouldn’t register with me. I can handle temperatures and distance in metric but not wind speeds.
                            • L Offline
                              linuxha
                              Ah feels like also needs to consider “windChill” & “heatIndex”. I’m betting they’re mutually exclusive.
                              • phodges7727P Offline
                                phodges7727
                                I think the weather.gov API using /points/ has been deprecated. It switched to gridpoints/{wfo}/{x}/{y}. I am not skilled enough to know what to switch in the config file to make it work.
