    default Weather, current with wethergov issues
    16 Posts 4 Posters 6.2k Views 4 Watching
      scumbelly @linuxha
      @linuxha
      This is what I am guessing is your weather.
        scumbelly @scumbelly
        @linuxha
        That’s odd. Your wind speed looks like it could be in meters/seconds but it should be about 3.3 @ 7 miles per hour. So, are you using the current weather module or the ‘new’ weather module?
        Cheers
        • L Offline
          linuxha @scumbelly
          @scumbelly , the new weather module, the old is call currentweather and weatherforecast. Those are commented out in my config.
            scumbelly @linuxha
            @linuxha
            With following set you should get correct weather… except wind chill.
            language: “en”,
            locale: “en-US”,
            logLevel: [“INFO”, “LOG”, “WARN”, “ERROR”], // Add “DEBUG” for even more logging
            timeFormat: 12,
            units: “imperial”,
            			type: "current",
            			weatherProvider: "weathergov", //Default value: openweathermap
            			weatherEndpoint: "/forecast/hourly",
            			degreeLabel: true,
            			showFeelsLike: false,
            			lat:        40.25571,
            			lon:        -74.39416,
            No matter what I tried Feels Like came up as 32degrees. The web site shows “wind chill” and openweathermap shows “feels like” and the current.njk translates “FEELS” - DEGREE. I’m scratching my head for now.
            Cheers.
              @linxha
              I captured an xml string from your location…
              <current_observation version=“1.0”
              xmlns:xsd=“http://www.w3.org/2001/XMLSchema”
              xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance”
              xsi:noNamespaceSchemaLocation=“http://www.weather.gov/view/current_observation.xsd”>
              NOAA’s National Weather Service
              <credit_URL>http://weather.gov/</credit_URL>
              http://weather.gov/images/xml_logo.gif
              NOAA's National Weather Service http://weather.gov 15 minutes after the hour 60 Belmar-Farmingdale, NJ KBLM 40.18333 -74.13333 Last Updated on Apr 14 2021, 12:56 pm EDT Wed, 14 Apr 2021 12:56:00 -0400 A Few Clouds 70.0 F (21.1 C) 70.0 21.1 39 from the West at 9.2 gusting to 17.3 MPH (8 gusting to 15 KT) West 270 9.2 17.3 8 15 1016.4 mb 1016.4 30.02 44.1 F (6.7 C) 44.1 6.7 10.00 http://forecast.weather.gov/images/wtf/small/ http://www.weather.gov/data/obhistory/KBLM.html few.png http://www.weather.gov/data/METAR/KBLM.1.txt http://weather.gov/disclaimer.html http://weather.gov/disclaimer.html http://weather.gov/notice.html
              … but I saw no ‘wind chill’ or ‘feels like’ information at the time I grabbed the file.
              I’ve gone about as far as I can. Hopefully someone can add more to this for you.
              Cheers.
              • L Offline
                linuxha @scumbelly
                @scumbelly , huge thanks for the help. What URL did you use to get the XML? For weather.gov, I’ve been seeing JSON.
                I think I’ll toss in a few log statements and see what weather.gov code is using.
                  scumbelly @linuxha
                  @linuxha
                  https://w1.weather.gov/xml/current_obs/KBLM.xml
                  • L Offline
                    linuxha
                    I figured out the Feels like being 32F, it’s getting a null in the heat index from weather.gov. I’ve added code to check for null and use the currentWeather.temperature instead. I’ll send diffs later (where do I send them?) when I’ve finished with the windSpeed.
                    		if(currentWeatherData.heatIndex.value) {
                    			currentWeather.feelsLikeTemp = this.convertTemp(currentWeatherData.heatIndex.value);
                    		} else {
                    			// If null, set it to the current temperature
                    			currentWeather.feelsLikeTemp = currentWeather.temperature;
                    Sorry it took so long for me to figure out this env. I’m using the browser to debug now. I’ve not done this much. :-)
                    • L Offline
                      linuxha
                      Okay, I see the issue with windSpeed. The URL returns windSpeed in km_h-1 (k/h), the convertSpeed(metSec) function appears to be m/s. I’m not sure how to fix this for general use. I’ll try to fix it for my use first.
                        sdetweil @linuxha
                        @linuxha google search on conversion says divide the km/h by 3.6 to get m/s
                        • L Offline
                          linuxha @sdetweil
                          @sdetweil , thanks, I did find those but I’m also trying to figure out a way so when I change the code it doesn’t break the existing. I’m just giving it thought now.
                          To convert kph to mph: *0.621371. I 'm used to MPH and m/s or kph wouldn’t register with me. I can handle temperatures and distance in metric but not wind speeds.
                          • L Offline
                            linuxha
                            Ah feels like also needs to consider “windChill” & “heatIndex”. I’m betting they’re mutually exclusive.
                            • phodges7727P Offline
                              phodges7727
                              I think the weather.gov API using /points/ has been deprecated. It switched to gridpoints/{wfo}/{x}/{y}. I am not skilled enough to know what to switch in the config file to make it work.
