    How to specify the Weather Type in a module which only uses the module name
    5 Posts 2 Posters 1.2k Views 2 Watching
    • O
      OldSunGuy
      I saw the following error msgs:
      [21.04.2021 15:12.39.799] [LOG]   Connecting socket for: currentweather
      [21.04.2021 15:12.39.800] [WARN]  The module 'currentweather' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
      [21.04.2021 15:12.39.802] [LOG]   Connecting socket for: weatherforecast
      [21.04.2021 15:12.39.803] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
      So I started looking at the documentation.
      I couldn’t find how to specify the forecast weather type for one slide, and the current weather type for another slide in the MMM-Carousel which my MM currently uses.
      Can somebody tell me?
      O 1 Reply Last reply
      • O
        OldSunGuy @OldSunGuy
        Here is my config of MMM-Carousel:
         module: "MMM-Carousel",
                  transitionInterval: 10000,
                  ignoreModules: ['alert', 'updatenotification', 'MMM-NewsFeedTicker'],
                  mode: 'slides',
                  slides: [
                           ['clock', 'calendar'],
                           ['clock', 'calendar', 'MMM-NetworkScanner'],
                           ['currentweather', 'weatherforecast', 'MMM-NetworkScanner'],
                           ['currentweather', 'weatherforecast', 'compliments'],
                           ['clock', 'calendar', 'compliments'],
                           ['clock', 'calendar', 'MMM-MoonPhase'],
                           ['currentweather', 'weatherforecast', 'MMM-MoonPhase'],
                           ['currentweather', 'weatherforecast']
        Can someone think of a way to use the new weather module in situation?
          sdetweil @OldSunGuy
          @oldsunguy said in How to specify the Weather Type in a module which only uses the module name:
          can u explain more… that sentence doesn’t give much info
          • O
            OldSunGuy @sdetweil
            Hi @sdetweil , Thanks for replying.
            I am trying to migrate from the currentweather and weatherforcast modules to the new weather module.
            I am using the MMM-Carousel module. It seemed strange (to me) to use the same module name. I was attempting to show the weather module with type=current on one slide and the weather module with type=forecast on another slide but with the same position. There didn’t seem to be any way to do this. I’ve since modified the config to use different positions so that a slide shows both current and forecast using the different positions.
            It kinda works as I am getting the correct header but it just shows “Loading…” ,
              sdetweil @OldSunGuy
              @oldsunguy yeh… it should support using the identifier as well as the name… that would make things a lot easier…
