    No autoplay for videos in v2.14 & v2.15
    9 Posts 2 Posters 2.5k Views 2 Watching
    • rudibaraniR
      rudibarani Project Sponsor
      Dear all,
      my MagicMirror ist running on a Mac Mini and I don’t have any problems when running on v2.13. If I upgrade to v2.14 or v2.15, autoplay of embedded videos is not working anymore. For the curious among you: I like playing a livestream of the ISS on my nighttime-mirror.
      The problem occurs with the electron versions that install with each release and are not resolved, if I upgrade electron to its latest version. Adding this line to electron.js did not have a positive effect as well:
      app.commandLine.appendSwitch(‘autoplay-policy’, ‘no-user-gesture-required’);
      Every module I have tried is affected, e.g. MMM-SmartWebDisplay, MMM-EARTH-Live, yframe, iFrame-Ping…
      Did someone else have this problem or does somebody have an idea what I could try do except staying on v2.13?
      Thanks!
      Phillip
        sdetweil @rudibarani
        @rudibarani said in No autoplay for videos in v2.14 & v2.15:
        this line is already present in electron .js
        function createWindow() {
        	app.commandLine.appendSwitch("autoplay-policy", "no-user-gesture-required");
        I put it there… for 2.10
        but according to electron page, they moved support from command line to web preferences
        https://www.electronjs.org/docs/api/browser-window
        so change electron.js like this
        	let electronOptionsDefaults = {
        		width: 800,
        		height: 600,
        		x: 0,
        		y: 0,
        		darkTheme: true,
        		webPreferences: {
        			contextIsolation: true,
        			nodeIntegration: false,
        			zoomFactor: config.zoom,
        			autoplayPolicy: "no-user-gesture-required"     // < --- moved to here
        		backgroundColor: "#000000"
        rudibaraniR 1 Reply Last reply Reply Quote 0
        • rudibaraniR
          rudibarani Project Sponsor @sdetweil
          @sdetweil said in No autoplay for videos in v2.14 & v2.15:
          width: 800,
          height: 600,
          x: 0,
          y: 0,
          darkTheme: true,
          webPreferences: {
          autoplayPolicy: “no-user-gesture-required” // < — moved to here
          backgroundColor: “#000000”
          Thank your for the suggestion, Sam. I tried it - but unfortunately without success. Autoplay of the ISS Livestream not starting with any of the modules. It works fine, when I go back to v2.13, though.
          http://www.ustream.tv/embed/17074538?html5ui&initial-quality=high&volume=0&autoplay=1
          Any additional thoughts would be much appreciated!
            @rudibarani well, we moved from electron 8 to 11, but only on 2.15
            • rudibaraniR
              I do to keep up with the latest version of electron via
              npm install electron@latest
              as I otherwise get a message saying something like “your browser is outdated” hovering above the ISS stream. The current electron version does autoplay with MagicMirror v2.13 - but not with a newer version of MagicMirror.
                @rudibarani comment out
                better yet, set it to false
                in the web preferences
                but that doesn’t explain 2.14
                • rudibaraniR
                  @sdetweil Thanks for the idea. This does not seem to cause the problem. Autoplay still refuses to cooperate…
                    @rudibarani if you wave the mouse over the mm screen does it work then?
                    • rudibaraniR
                      @sdetweil No - I need to click on the “play” button on the stream.
