    MagicMirror Raspberry Pi 0 W
    9 Posts 3 Posters 2.7k Views 3 Watching
    • unfriendlydeviceU Offline
      unfriendlydevice @lifetech
      @lifetech I ran my original mirror on a Pi Zero using the image provided here: http://emmanuelcontreras.com/how-to/how-to-create-a-magic-mirror-2-with-pi-zero-w
        sdetweil @unfriendlydevice
        @unfriendlydevice don’t care… use the latest stuff… many of the docs don’t get updated (that is 2017, 4 YEARS ago(
        jessie and stretch are too old
        use buster
        use my script… there are settings that MUST be done, and u won’t have them
        electron is not available for armv6l anymore
        unfriendlydeviceU 1 Reply Last reply Reply Quote 0
          unfriendlydevice @sdetweil
          @sdetweil The image uses Chromium and was last updated April 2020, not completely up to date but definitely not from 2017!
            @unfriendlydevice ok… still doesn’t work tho… so…
            • L Offline
              lifetech @sdetweil
              @sdetweil it was missing alot of dependencies and giving alot of errors when I tried before. Is it a good known install?
                sdetweil @lifetech
                @lifetech my script is a good installer, and I will fix it if not. I support it on more platforms than MM supports
                • L Offline
                  lifetech @sdetweil
                  @sdetweil THANKS MAN! I think I’m finally able to play around with this thing
