    Mirror-remote app (android)
    8 Posts 2 Posters 2.3k Views 3 Watching
    • ultalexU Offline
      ultalex
      Application for the MMM-Remote-Control module.
      Works only on Wi-Fi networks.
      Inaccuracies with the translation into English are possible, please advise how the translation could be corrected. I will also be glad to have ideas for new features or widgets and translations.
      Implemented:
      Power and monitor management;
      Displaying system information about the raspberry pi; (changes are required in the MMM-Remote-Control module)
      VNC launch; (changes are required in the MMM-Remote-Control module)
      Widgets for switching profiles, timer, stopwatch, breathing exercises, installed modules (test widget);
      The widget displays the module required for installation;
      2 languages: Russian (main), English (additional)
      Shortcuts;
      Working with multiple mirrors;
      Switching pages;
      Custom commands.
      Password for admin mode Admin
      Home
      Modules
      Settings
      Add mirror
      Add command
      Shortcuts
      App
      Changes in the MMM-Remote-Control module
      api.js add to line 109 (after this.configOnHd.modules.filter(mod => skippedModules )
      //системный монитор
      		getStats: function() {
                  var fs =  require('fs');
                  var os =  require('os');
                  var stats = ''
                  var temperature = fs.readFileSync("/sys/class/thermal/thermal_zone0/temp");
                  temperature = ((temperature/1000).toPrecision(3));
                  var cpu = fs.readFileSync("/proc/loadavg");
                  cpu = cpu.slice(0,4);
                  var upTime = fs.readFileSync("/proc/uptime");
                  stats = 'temp: '+temperature+'; '+'cpu: '+cpu+'/'+os.cpus().length+'; '+'ram: '+Math.floor(os.freemem()/os.totalmem()*100)+'; '+'uptime: '+os.uptime()+';';//+'memory: '+memory+';';
                  return stats;
              //запуск VNC
      		startVNC: function() {
                  var exec = require('child_process').exec;
                  exec('vncserver-x11 -showstatus');
                  return 'OK';
      api.js add to line 156 (after this.expressRouter.route([‘/test’,‘/’]) )
      this.expressRouter.route(['/systemStats']) // //системный монитор без apiKey
                  .get((req, res) => {
                      if (!this.checkInititialized(res)) { return; }
                      res.json({ data: this.getStats() });
      api.js add to line 226 (after this.expressRouter.route([
      ‘/refresh/:delayed?’, )
      this.expressRouter.route(['/startVNC']) // запуск VNC
                      if(!this.apiKey && this.secureEndpoints) return res.status(403).json({ success: false, message: "Forbidden: API Key Not Provided in Config! Use secureEndpoints to bypass this message" });
                      res.json({ data: this.startVNC()});
      ultalexU 2 Replies Last reply Reply Quote 1
      • ultalexU Offline
        ultalex @ultalex
        • ultalexU Offline
          ultalex
          Added the ability to change the volume of the mirror (MMM-Volume).
          • ultalexU Offline
            ultalex @ultalex
            Added draft French and German
            Fixed minor bugs
            • ultalexU Offline
              ultalex
              Added the ability to change the configuration of modules (Test function) ModulesConfig.jpg
              • ultalexU Offline
                ultalex
                Added mirror configuration setting and editing of custom commands
                  sophiaholloway
                    sophiaholloway
                    I like your article, I really like kinemaster mod apk no password , good video and image editing app for android phone.
                    1 Reply Last reply Reply Quote -1
