    Problem mit MMM-Fuel (Textausrichtung)
    12 Posts 3 Posters 4.9k Views 3 Watching
      Pielo @Sven1894
      @Sven1894
      Danke für deine Antwort. Leider brachte das auch keine Änderung. Vielleicht kannst du ja irgendwo einen Fehler entdecken.
      config.js
      /* Magic Mirror Config Sample
       * By Michael Teeuw http://m...content-available-to-author-only...w.nl
       * MIT Licensed.
       * See https://g...content-available-to-author-only...b.com/MichMich/MagicMirror#configuration
      var config = {
      	address: "0.0.0.0", // Address to listen on, can be:
      	port: 8080,
      	ipWhitelist: ["127.0.0.1", "192.168.2.??", "192.168.2.??"], // Set [] to allow all IP addresses
      	language: "de",
      	timeFormat: 24,
      	units: "metric",
      			     // false, default for all  NON-armv6l devices
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "Kalender",
      						url: "https://calendar.google.com/calendar/ical/????????????????????????/basic.ics"
      			module: "compliments",
      			position: "lower_third"
      			module: 'MMM-NOAA3',
      			position: 'right',
             				provider: "weatherbit", // From list above
             				apiKey: "b7b???????????????",        // From one of the providers listed above
      				airKey: "",
             				css: "NOAA3",                   // THIS MUST CONTAIN A CSS STYLE NAME
         				userlat: "50.65", //MUST HAVE BOTH
             				userlon: "11.4333"  //MUST HAVE BOTH
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "Deutsche Welle - Themen des Tages",
      						url: "https://r...content-available-to-author-only...w.com/xml/rss-de-top"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
                		module: "MMM-Fuel",
                 			api_key: "c3c21eac-5a2f-003a-403c????????????",
                  			lat: 50.660189,
                  			lng: 11.440749,
                  			types: ["e5"],
      				max: 3,
      				shortenText: true,
      				showAddress: true
      			module: 'MMM-MyGarbage',
      			position: 'top_left',
      			header: 'My Garbage Calendar',
      	        		alert: 4,
      	         		weeksToDisplay: 2,
              	 		limitTo: 99,
              	 		fade: true,
              			dateFormat: "dddd D MMMM",
              			fadePoint: 0.25
                 		module: "MMM-Temperature",
      	      		position: "right",
      		     	sensors: [
      			module: 'MMM-WiFiPassword',
      				//See 'Configuration options' for more information.
      				network: "Speedy oder HiSpeedy",
      				password: "12796????????????",
      			module: 'MMM-AlexaPi',
      			position: 'lower_third',
      				showAddress: false,
      				rotate: false,
      			    // If no config is set, defualt values are used
      			module: 'MMM-Todoist',
      			position: 'top_center',	// This can be any of the regions. Best results in left or right regions.
      			header: 'Todoist', // This is optional
      			config: { // See 'Configuration options' for more information.
      				hideWhenEmpty: false,
      				accessToken: '14175821dae1c7302f8??????????????',
      				maximumEntries: 60,
      				updateInterval: 10*60*1000, // Update every 10 minutes
      				fade: false,
      				// projects and/or labels is mandatory:
      				projects: [ 166?????? ],
      				labels: [ "MagicMirror", "Important" ] // Tasks for any projects with these labels will be shown.
      MMM-Fuel.css
      .MMM-Fuel .table {
          border-spacing: 10px 0;
          border-collapse: separate;
      .MMM-Fuel .logo {
          margin-right: 5px;
      .MMM-Fuel .sortBy {
          margin-left: 5px;
      .MMM-Fuel .centered {
          text-align: left;
      .no-color .MMM-Fuel-map {
          -webkit-filter: grayscale(100%);
        Sven1894 @Pielo
        @Pielo Hmmm… Für mich sieht es so aus als sei die Schrift nur in der Tabelle zentriert und nicht im ganzen Modul. Die Überschrift vom Modul ist ja linksbündig. Versuch mal folgendes:
        .MMM-Fuel .table {
            text-align: left;
        P 2 Replies Last reply
          Pielo @Sven1894
          @Sven1894
          Stimmt, auch die Überschriften der anderen zwei Spalten sind rechtsbündig. Leider hat aber deine Idee nicht funktioniert. Ich habe es hier noch mal ein besseres Bild angehängt. Vielleicht fällt dir ja noch was ein.
          alt text
            Sven1894 @Pielo
            @Pielo Kannst du mir vielleicht noch deine custom.css zeigen? Vielleicht kann ich da etwas finden.
            P 1 Reply Last reply
              Pielo @Sven1894
              @Sven1894
              Die ist (bis jetzt) ohne Inhalt.
              Kann doch nicht sein, das es bei mir so problematisch ist…
                Pielo @Sven1894
                Ich bin zu einer neuen Erkenntniss gekommen. Wenn ich das Wettermodul entferne ist es linksbündig. Zwar immernoch nur ein Buchstabe, aber schon mal was. Das selbe ist auch, wenn ich alle anderen Module entferne.
                Die Funktion zu “shortenText” ist folgende. Kann man da evtl erkennen warum nur ein Buchstabe angezeigt wird. Muss irgendwo noch ne breite deklariert werden?
                    * @function shortenText
                    * @description Shortens text based on config option (shortenText) and adds ellipsis at the end.
                    * @param {string} text - Text which should be shorten.
                    * @returns {string} The shortened text.
                   shortenText(text) {
                       let temp = text;
                       if (this.config.shortenText && temp.length > this.config.shortenText) {
                           temp = `${temp.slice(0, this.config.shortenText)}…`;
                       return temp;
                alt text
                  Sven1894 @Pielo
                  @Pielo Kannst du mir mal die css des Wettermoduls zeigen?
                  Davon abgesehen solltest du Änderungen in css lieber in der custom css machen und die css-Dateien der Module nicht verändern.
                  Ich bin zwar kein JavaScript Profi, aber ich versuche mal zu helfen.
                  Bei der slice Funktion muss, soweit ich weiß, als Startwert ein Integer und als Endwert ein Integer angegeben werden. “this.config.shortenText” ist aber ein boolean, oder? Meine Vermutung ist, dass das der Fehler ist.
                  Aber wie gesagt, ich bin kompletter Anfänger was JavaScript angeht, kann auch sein, dass ich hier völligen Blödsinn erzähle.
                    chris47803
                    Hallo,
                    ich habe das gleiche Problem.
                    Eine Kollision mit anderen Modulen kann ich ausschließen.
                    Es kommt auch immer drauf an welche Tankstellen von Tankerkönig über die API kommen.
                    ShortenText auf true zeigt nur einen Buchstaben an, was nichts nützt.
                    Hat schon Jemand eine Lösung gefunden?
                    C 1 Reply Last reply
                      chris47803 @chris47803
                      @chris47803 said in Problem mit MMM-Fuel (Textausrichtung):
                      Hallo,
                      I have the same problem.
                      I can rule out a collision with other modules.
                      It always depends on which petrol stations from Tankerkönig come via the API.
                      ShortenText to true only shows one letter, which is of no use.
                      Has anyone found a solution yet?
                        Ich klatsch mir vor die Stirn. :)
                        Bei ShortenText habe ich nun statt true oder false den Wert 50 eingetragen.
                        Nun passt es.
                        LG, Chris
