    How Can I Mount my smart mirror to a wall?
    18 Posts 5 Posters 8.6k Views 5 Watching
    • DentraxD
      Dentrax Module Developer @sdetweil
      @sdetweil said in How Can I Mount my smart mirror to a wall?:
      @dentrax u would mount it on the BACK surface, not the TOP
      red is the wire from the two hangers
      to keep the unit appearing flush against the wall, you would need to add two bumpers at the bottom
      same thickness of the a mount on the back…
      the A hanger will rotate toward the wire centerpoint
      Oh, I see now. Thanks for the illustration! That’s makes sense. But… I’m not sure if I can screw it into that narrow slider. It’s exactly 7mm. The sliding system will be broken, if the screw is long enough. 🤔 But at the same time, the hanger needs to be attached strongly. That’s my concern. :(
      alt text
        sdetweil @Dentrax
        @dentrax you are not screwing into the space with the slot, more the outside edge, in the 10mm NOT slotted
        that is why I said its a shame, you don’t need so much slot… but too late now
        u need the back panel to slide out without removing any fasteners… u said that in the beginning
        but the slot is why you do not want to use C as the twisting could break the slot…
        DentraxD 1 Reply Last reply
        • DentraxD
          Thanks! I brought 2 Cs and 4 As yesterday. I’m sharing pictures to confirm if I fully understand what you’re proposing. :)
          Making two screws to Cs will apply twisting force. I agree that. I guess a use-case like the first picture I drew is a bit risky, right?
          Also, I’m thinking that is it more risky to attach a single screw both sides, since we only 10mm area, which is why we need to use strong screws, i guess. I just want to be sure that it’s reinforced enough as well.
          I’m sorry that I keep pinging you about this thread. I hope this thread will help other people as well from whom come from search engines. (Or maybe it’s just a specific case for me, lol)
          alt text
          alt text
            sdetweil @Dentrax
            @dentrax last pic, correct, in that 10mm space.
            you want the weight to be hanging, so the mounts nearear the top
            and for 1st pic, no C, just wire from A to center point and back down to A on the other side,
            the A closest to the top
            A will rotate a little on its screw to point to the center of the cable
            you could use C as well, using only the bottom screw… so it rotates…
            this would allow the loop of cable at C to be in the open space behind the mirror, reducing the protusion from the wall to just the thickness of the mounting flange
            strong screws, yes, but make it long too… at least 1/2 the thickness of your side panel
            they make them for holding kitchen cabinets which are indestructible…
            but this is not much weight
            u want a flat head screw , to keep the protrusion small as well
            there is not much force pulling away from the back surface, only sideways to the center
            • DentraxD
              Thank you so much! I’m just thinking if I don’t want to use a “hanger wire”, can i do it this way? And for the wall (hanging) side, I can go with something like “L screw hook hanger”, as the following in the second picture. What do you think?
              alt text
              alt text
                sdetweil @Dentrax
                @dentrax the smaller screw, flat head, maybe longer. at least 1/2 the size of the side
                drill a pilot hole so u don’t crack the material.
                hanger wire for sure, and a picture hook. they can hold up to 25kg.! the cable gives you the ability to balance and straighten
                  doogy_rev @sdetweil
                  I used a French cleat on mine, one top and bottom
                  https://images.homedepot-static.com/productImages/798600fb-cfa2-45b3-87a5-f19be3a097cc/svn/hangman-picture-mirror-hanging-cbh-30-64_1000.jpg
                    sdetweil @doogy_rev
                    @doogy_rev because of his sliding back panel he has no material on the top to used one of these
                      doogy_rev @sdetweil
                      Could always put a piece of batten across to fill the gap, just screw through that in to the frame it will then sit flush
                      • O
                        OberfragGER @Dentrax
                        @dentrax What about french cleat?
                        https://en.wikipedia.org/wiki/French_cleat
                        Thats the way i mountet my MM. Its vers stable and always horizontal.
