Weather Module Current Forecast
6 Posts 2 Posters 790 Views 2 Watching
    ankonaskiff17
    I’ve hit a wall on getting the hourly forecast to work.
    It seems straightforward, instead of /forecast I use forecast/hourly but it just wont go.
    I went to weather.gov site and I can find stuff about gridpoints and following their instructions get a result.
    The other part and where I am way over my head is I ran across some lines that say something to effect that api.weather.gov/points/forecast/hourly are deprecated where api.weather.gov/points/forecast is not.
    I’m stuck
    S 1 Reply Last reply Jun 18, 2021, 12:53 AM Reply Quote 0
      sdetweil @ankonaskiff17
      @ankonaskiff17 you use /forecast
      that is the only choice
      weatherEndpoint: “/forecast”
      The hourly type is currently only implemented
      for the OpenWeatherMap provider, and only
      when /onecall is used as the specified endpoint.
      so
      type:“hourly”,
      weatherEndpoint:“/onecall”,
      weatherProvider:“openweathermap”
      A 1 Reply Last reply Jun 18, 2021, 12:23 PM Reply Quote 0
        ankonaskiff17 @sdetweil
        @sdetweil So for time being its best to stick with Current Weather module that I already have up and running on different device. I can just copy/paste and be done with it since it works using openweathermap.
        A 1 Reply Last reply Jun 18, 2021, 7:03 PM Reply Quote 0
          ankonaskiff17 @ankonaskiff17
          @ankonaskiff17 FWIW, the weathergov “forecast/current” loaded at some point… I posted message about last evening about hitting wall. Quit for the day and powered down monitor which I just turned on and it was up and running. I’ve rebooted and it is in that “Loading…” mode similar to what was resolved on the forecast module. I started stopwatch to see how long it takes to load. Surprised me that’s for sure. I was sitting there looking at it for a couple of minutes before it sank in to my brain.
          S 1 Reply Last reply Jun 18, 2021, 7:46 PM Reply Quote 0
            @ankonaskiff17 loading… is the default text modules put up while they are waiting for data.
            if there is some problem they don’t usually tell u. they are wating
            A 1 Reply Last reply Jun 19, 2021, 1:27 PM Reply Quote 0
              @sdetweil I understand that. It had “loading” displayed when I went to bed but when I got up forecast/current had loaded and was displaying the current forecast.
              So in some respect weathergov forecast/current was functional,
