Wake up/Hibernate display
11 Posts 4 Posters 2.4k Views 4 Watching
    CheapDad
    I’m using a monitor in my project that does NOT have HDMI. I’m using an DVI to HDMI adapter to make it work.
    Do I have any options for allowing the monitor to go to sleep and then wake up when needed? Note that a PIR sensor does not work because I don’t have HDMI.
    G S 2 Replies Last reply Jun 19, 2021, 5:50 PM Reply Quote 0
    • G Offline
      George @CheapDad
      @cheapdad , Hi, what’s the connection between HDMI and PIR? I built three mirrors, all three have adapters and use PIR.
      C 1 Reply Last reply Jun 19, 2021, 9:30 PM Reply Quote 0
      • S Away
        sdetweil @CheapDad
        @cheapdad u can still turn off the hdmi output… the monitor might show ‘no input’… which mine do…
        so I went to blanking (hide all modules)…
        C 1 Reply Last reply Jun 19, 2021, 9:33 PM Reply Quote 0
          CheapDad @George
          @george said in Wake up/Hibernate display:
          I understood that the PIR sensor uses HDMI-CEC to communicate shutting off the monitor. Is that not true?
          S G 2 Replies Last reply Jun 19, 2021, 9:32 PM Reply Quote 0
          • S Away
            sdetweil @CheapDad
            @cheapdad no. PIR signals software. there are three different ways
            C 1 Reply Last reply Jun 19, 2021, 9:38 PM Reply Quote 0
              CheapDad @sdetweil
              @sdetweil said in Wake up/Hibernate display:
              How do you do that?
                CheapDad @sdetweil
                @cheapdad no. our signals software. there are three different ways
                I’m sorry but I don’t understand this at all.
                No, the PIR sensor does not use HDMI-CEC?
                What signals software are you referring to?
                What are the 3 different ways?
                S 2 Replies Last reply Jun 19, 2021, 10:20 PM Reply Quote 0
                • S Away
                  sdetweil @CheapDad
                  @cheapdad sorry, typo.
                  phone didn’t like the word PIR
                  pir is a heat sensor
                  it signals, heat, and then no heat. that is all.
                  software has to make intelligent work from that
                  the PIR modules see heat, and turns ON the display
                  they see no heat, and some time later turns OFF the display
                  actually 4 ways to turn on/off the display/source, all commands u can issue
                  tvservice
                  vcgencmd
                  dpms
                  and the latest to turn off the display
                  cec-utils
                  many of the pir modules allow you to choose which approach u want to use.
                  some people are unable to use any of those (me)
                  so I wrote a module to hide the modules
                  • S Away
                    sdetweil @CheapDad
                    @cheapdad and there two more ways, that need software
                    you can control a switch/relay that turn the power off /on to the display, for those monitors that don’t have internal controls that prevent this. (my monitors do not come back on after a power failure)
                    and you can modify the logic of the didplay with a relay/switch to turn on/off the backlight of the display. so the display is powered on, but not active
                    • G Offline
                      George @CheapDad
                      @cheapdad , in my mirrors the PIR sensor stop the display of the modules but the monitor continues to work, it display a black screen.
                      S 1 Reply Last reply Jun 20, 2021, 8:55 PM Reply Quote 0
