Mirror crashes daily and pm2 doesn't get it up again
Hi!
My mirror crashes every day. It just goes black and works again if I manually quit it (pm2 will then restart it).
I checked the logs by doing
pm2 logs mmWhich gives me:
[TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option) /home/pi/.pm2/logs/mm-error.log last 15 lines: 0|mm | rning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2) 0|mm | [16.06.2021 10:58.04.258] [ERROR] (node:939) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. 0|mm | [16.06.2021 19:30.11.075] [WARN] (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false". It will change to be "true" in Electron 9. For more information please check https://github.com/electron/electron/issues/18397 0|mm | [17.06.2021 05:30.22.142] [ERROR] (node:8664) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 NOTIFY listeners added to [EventSource]. Use emitter.setMaxListeners() to increase limit 0|mm | [17.06.2021 05:30.22.155] [ERROR] (node:8664) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 STATUS listeners added to [EventSource]. Use emitter.setMaxListeners() to increase limit 0|mm | [17.06.2021 05:30.22.159] [ERROR] (node:8664) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 EVENT listeners added to [EventSource]. Use emitter.setMaxListeners() to increase limit 0|mm | [8713:0617/083204.668041:FATAL:memory.cc(22)] Out of memory. size=88473600 0|mm | [17.06.2021 12:59.20.996] [WARN] (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false". It will change to be "true" in Electron 9. For more information please check https://github.com/electron/electron/issues/18397 0|mm | [13452:0617/205251.489565:FATAL:memory.cc(22)] Out of memory. size=88473600 0|mm | [18.06.2021 14:24.55.633] [WARN] (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false". It will change to be "true" in Electron 9. For more information please check https://github.com/electron/electron/issues/18397 0|mm | [18.06.2021 14:33.07.564] [WARN] (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false". It will change to be "true" in Electron 9. For more information please check https://github.com/electron/electron/issues/18397 0|mm | [19.06.2021 00:33.15.146] [ERROR] (node:19706) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 NOTIFY listeners added to [EventSource]. Use emitter.setMaxListeners() to increase limit 0|mm | [19.06.2021 00:33.15.156] [ERROR] (node:19706) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 STATUS listeners added to [EventSource]. Use emitter.setMaxListeners() to increase limit 0|mm | [19.06.2021 00:33.15.159] [ERROR] (node:19706) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 EVENT listeners added to [EventSource]. Use emitter.setMaxListeners() to increase limit 0|mm | [19755:0619/134817.487939:FATAL:memory.cc(22)] Out of memory. size=88473600 /home/pi/.pm2/logs/mm-out.log last 15 lines: 0|mm | [19.06.2021 20:07.22.143] [INFO] Calendar-Fetcher: Broadcasting 12 events. 0|mm | [19.06.2021 20:12.32.306] [INFO] Calendar-Fetcher: Broadcasting 12 events. 0|mm | [19.06.2021 20:17.42.082] [INFO] Calendar-Fetcher: Broadcasting 12 events. 0|mm | [19.06.2021 20:22.51.820] [INFO] Calendar-Fetcher: Broadcasting 12 events. 0|mm | [19.06.2021 20:28.01.490] [INFO] Calendar-Fetcher: Broadcasting 12 events. 0|mm | [19.06.2021 20:33.11.508] [INFO] Calendar-Fetcher: Broadcasting 12 events. 0|mm | [19.06.2021 20:38.21.877] [INFO] Calendar-Fetcher: Broadcasting 12 events. 0|mm | [19.06.2021 20:43.32.020] [INFO] Calendar-Fetcher: Broadcasting 12 events. 0|mm | [19.06.2021 20:48.41.909] [INFO] Calendar-Fetcher: Broadcasting 12 events. 0|mm | [19.06.2021 20:53.52.000] [INFO] Calendar-Fetcher: Broadcasting 12 events. 0|mm | [19.06.2021 20:59.02.028] [INFO] Calendar-Fetcher: Broadcasting 12 events. 0|mm | [19.06.2021 21:04.12.077] [INFO] Calendar-Fetcher: Broadcasting 12 events. 0|mm | [19.06.2021 21:09.22.303] [INFO] Calendar-Fetcher: Broadcasting 12 events. 0|mm | [19.06.2021 21:14.32.500] [INFO] Calendar-Fetcher: Broadcasting 12 events. 0|mm | [19.06.2021 21:19.42.322] [INFO] Calendar-Fetcher: Broadcasting 12 events.Any ideas on how I could fix this?
I just did a
git pull && npm installTo see if it makes a difference.
:astonished_face: @looolz
log says:
17.06.2021 05:30.22.159] [ERROR] (node:8664) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 EVENT listeners added to [EventSource]. Use emitter.setMaxListeners() to increase limit 0|mm | [8713:0617/083204.668041:FATAL:memory.cc(22)] Out of memory. size=88473600So first thing to verify: what is the module who do this
so isolate (disable module one by one for verify)when you found the module trouble:
try a git pull on it
If not works gain … report issue to developer -
@bugsounet Thank you! If it crashes again, I’ll start by disabling 1/2 of the modules until I find the problem. This could take days, hope I don’t have to 😐
