News feed not loading and how not to translate them
5 Posts 3 Posters 3.0k Views 3 Watching
    albaace
    I can’t get to work the news feed modules. I am using the MM2 in spanish and the news feed page is in catalan. I used RSS but still not working, says it is loading. Could this problem be due to the translations? How can I make that the news feed don’t get translated?
      chrisfoerg
      Can you post your config?
        albaace
        It is the original config but i changed the language to spanish (lang:es) and the news feed to “http://www.ara.cat/rss.html”. @chrisfoerg
        Here is the config:
        The config file
        var config = {
        port: 8080,
        language: 'es',
        timeFormat: 24,
        units: 'metric',
        		module: 'newsfeed',
        		position: 'bottom_bar',
        			feeds: [
        					title: "Diari Ara",
        					url: "http://www.ara.cat/rss.html"
        			showSourceTitle: true,
        			showPublishDate: true
        • Y Offline
          yawns Moderator
          use url: 'http://www.ara.cat/rss' instead
          You linked to http://www.ara.cat/rss.html which is a landing page, the real rss feed (xml based) is http://www.ara.cat/rss
            albaace
            Perfect! It works. Thank you very much @chrisfoerg
