    Make Center Area Less Wide
    10 Posts 4 Posters 2.5k Views 3 Watching
    • amarandA Offline
      amarand @sdetweil
      Is there specific custom.css code I need to use, to make the center column narrower, and the right and left columns wider to fit that space?
        sdetweil @amarand
        @amarand i don’t know, never done it.
        but you’ll see that center is 100% width, so you will have to make a new left edge too.
        for figuring this out read this
        https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1625536307526
        amarandA 1 Reply Last reply Reply Quote 0
        • amarandA Offline
          amarand @sdetweil
          I am so sorry, but is there a MagicMirror related CSS tutorial somewhere that explains all of the possible configuration settings that I can change/override in the custom.css, maybe with examples?
          For example, I agree, I think it’d be awesome to be able to change the column background colors to see how things are adjusting, but so far, I’ve only been able to figure out how to change the entire module area color by adding the following to the body section of my custom.css file:
          –color-background: #800;
          It makes the 60px “gaps” around the outside glaringly obvious (black versus red).
          S ? 2 Replies Last reply Reply Quote 0
            sdetweil @amarand
            @amarand said in Make Center Area Less Wide:
            no… the body clause set a 60px border around the screen… which individual background colors won’t fill…
            sorry, there are hundreds of settings on the MM ‘web page’
              A Former User @amarand
                A Former User @Guest
                • BKeyportB Offline
                  BKeyport Module Developer @Guest
                  @hango That’ll do it, but if I recall correctly, if you set bottom center and top center to 20%, left and right will automatically take up the slack, no need to convert them, conversely, if you set left or right to 40%, the remaining 60% would automatically be split between them.
                    A Former User @BKeyport
