    Calendar 'line' - where is the code?
    11 Posts 3 Posters 8.9k Views 3 Watching
      chrisfoerg
      I didn’t try it but I think yes. the easiest way is to copy the header and delete all you don’t need. I think you also can erase the . before header
      • V Offline
        valid8r @chrisfoerg
        @chrisfoerg Got it working, thanks. Why does “header” not need the “.header”???
          chrisfoerg
          I had to search for it
          p {…}
          applies to
          elements
          .p {…}
          applies to all elements with with class “p” eg
          , etc
          I don’t know the html code but html5 uses
          V 2 Replies Last reply Reply Quote 0
          • V Offline
            valid8r @chrisfoerg
            @chrisfoerg Interesting. As I said before, the education process continues! Thanks Chris.
            • V Offline
              valid8r @chrisfoerg
              @chrisfoerg Ok, in my continuing process, I beg of you again for help! Now I am trying to change the font color for the temperature class defined in the currentweather module. I thought I should use
              .temperature {
              color: red;
              but no go. I also tried using
              .currentweather .temperature {
              color: red;
              but also no go… Thoughts?
              • H Offline
                Hacksaw
                currentweather.js
                Line 307:
                	temperature.className = "bright"; <-- this Line
                change to:
                            temperature.className = "brightt";
                in the custom.css
                Insert:
                .brightt {
                color: #FF0000;
                Reboot
                • V Offline
                  valid8r @Hacksaw
                  @Hacksaw Thanks, but is there no way to do so without modifying the actual module js code so that the only changes are to custom.css?
