    Calendar 'line' - where is the code?
    11 Posts 3 Posters 9.3k Views 3 Watching
    • V Offline
      valid8r
      I’m searching for the code that defines the horizontal line spanning the iFrame module for the Calendar module (also for the line in the default weather module). I searched the .js and the .css files but don’t see anything defining this.
      Thanks in advance
        chrisfoerg
        I think it’s in the folder css file main.css
        header {
        text-transform: uppercase;
        font-size: 15px;
        font-family: “Roboto Condensed”;
        font-weight: 400;
        border-bottom: 1px solid #666;
        line-height: 15px;
        padding-bottom: 5px;
        margin-bottom: 10px;
        color: #999;
        • V Offline
          valid8r @chrisfoerg
          @chrisfoerg Ahh, didn’t look there. Will play with that now.
          • V Offline
            valid8r @valid8r
            @valid8r So, if I wanted to change the color of the header using my custom.css would I use something like:
            .header {
            color: #99F;
              chrisfoerg
              I didn’t try it but I think yes. the easiest way is to copy the header and delete all you don’t need. I think you also can erase the . before header
              • V Offline
                valid8r @chrisfoerg
                @chrisfoerg Got it working, thanks. Why does “header” not need the “.header”???
                  chrisfoerg
                  I had to search for it
                  p {…}
                  applies to
                  elements
                  .p {…}
                  applies to all elements with with class “p” eg
                  , etc
                  I don’t know the html code but html5 uses
                  V 2 Replies Last reply Reply Quote 0
                  • V Offline
                    valid8r @chrisfoerg
                    @chrisfoerg Interesting. As I said before, the education process continues! Thanks Chris.
                    • V Offline
                      valid8r @chrisfoerg
                      @chrisfoerg Ok, in my continuing process, I beg of you again for help! Now I am trying to change the font color for the temperature class defined in the currentweather module. I thought I should use
                      .temperature {
                      color: red;
                      but no go. I also tried using
                      .currentweather .temperature {
                      color: red;
                      but also no go… Thoughts?
                      • H Offline
                        Hacksaw
                        currentweather.js
                        Line 307:
                        	temperature.className = "bright"; <-- this Line
                        change to:
                                    temperature.className = "brightt";
                        in the custom.css
                        Insert:
                        .brightt {
                        color: #FF0000;
                        Reboot
                        • V Offline
                          valid8r @Hacksaw
                          @Hacksaw Thanks, but is there no way to do so without modifying the actual module js code so that the only changes are to custom.css?
