    MMM-awesome-alexa Error
    Scheduled Pinned Locked Moved Forum
    4 Posts 2 Posters 955 Views 2 Watching
      MassiveArts 0
      Hey, I’m having problems with the Alexa installation.
      $ cd ~/MagicMirror/modules # Navigate to module folder
      $ git clone https://github.com/dolanmiu/MMM-awesome-alexa.git # Clone this repository
      $ cd MMM-awesome-alexa # go into the module directory
      $ npm install --only=prod # Install depdendencies
      $ cd node_modules
      $ rm -rf snowboy # Remove the installed snowboy
      $ git clone https://github.com/Kitt-AI/snowboy.git # Manually get snowboy from git
      $ cd snowboy # Go into the /snowboy directory
      $ rm -rf node_modules
      $ npm install nan --save # Make sure you install this in the /snowboy directory
      $ npm install node-pre-gyp@0.12.0 --save # Make sure you install this in the /snowboy directory
      $ npm install # Make sure you install in the /snowboy directory
      $ npm run prepublish # Make sure you run this in the /snowboy directory
      $ npm install --save-dev electron-rebuild # Make sure you install this in the /snowboy directory
      Bild_2021-07-10_204921.png $ npm install nan # Make sure you install this in the /snowboy directory
      $ ./node_modules/.bin/electron-rebuild # Build snowboy to your device specifications, in the /snowboy directory
        sdetweil @MassiveArts 0
        @massivearts-0 use my script to do all that , too many chances for copy/paste or retype errors
        https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0
        download, make executable and then run it…
        doesn’t matter where u download or execute, it does the whole thing…
        clones the module. etc
        ignore the errors til the last line
          MassiveArts 0 @sdetweil
          @sdetweil said in MMM-awesome-alexa Error:
          Where should I put this?
            @massivearts-0 wherever you want… doesn’t matter
            I make a folder called temp to put temp things in
