    Problem with MMM-CalendarEXT
    13 Posts 4 Posters 5.8k Views 4 Watching
      daniellang
      language: "de",
      timeFormat: 24,
      units: "metric",
      			module: 'MMM-CalendarExt',
      			position: "lower_third", //anywhere. It is not related to real position of view
      			config: { // Read below
      			system: {
      			  show: ['daily'],
      			  locale: 'de', //when omitted, default value would be your system default locale by moment.js
      			  showEmptyView: 0,
      			  fullDayEventLocalize: 1,
      			  redrawInterval: 30*60*1000, //minimum 60000
      			  useProfileConfig: 0,
      			  startProfile: ''
      			 views: {
      					current: {
      					  title: "Heute",
      					  limit: 3,
      					upcoming: {
      					  title: "Demnächst",
      					  limit: 3,
      					daily: {
      					  position: "bottom_bar",
      					  title: "Überblick",
      					  counts: 7,
      if (typeof module !== “undefined”) {module.exports = config;}
        [[global:former-user]] @daniellang
        @daniellang
        Because your quoted configuration looks not complete, I cannot assure. But the error message says there is some syntax error in your configuration. Many cases are misspellings, missing some marks(,, {, }, [, ], ", ', etc…).
        Anyway I’ve found something.
        “ is not proper double-quotation mark for javascript. Instead, you should use ".
        So, it should be like this;
        You could remove and re-insert sections one-by-one to check which section has a problem.
          daniellang @Guest
          @sean cant find the wrong marks…
            @daniellang
                  //disabled:true,
                  position: "top_center",
                    system: {
                      show: ["daily", "upcoming"],
                      locale: 'en',
                      redrawInterval:60000,
                    views: {
                      daily: {
                        position:'bottom_bar',
                        counts:7,
                      upcoming: {
                        position:'top_left',
                        limit:5
                    defaultCalendar: {
                      maxEntries:50,
                      maxDays:180,
                      interval: 1000*60*5,
                    calendars :[
                        symbol: "calendar-o",
                        styleName: "style1",
                        url: "http://www.kayaposoft.com/enrico/ics/v1.0?country=deu&fromDate=01-01-2017&toDate=31-12-2017&region=Hesse"
            I think you just copied my configuration sample. It has no bugs. try it again.
            (Anyway, that sample is out-of-date, so there is no event to display at this moment.)
              daniellang
              no errors now…but the screen stay black…@sean sorry for disturbing…
                daniellang
                sag bist du deutscher? llooollll
                  @daniellang
                  Leider meine Deutsche ist nicht so gut. :(
                  That iCal url of above sample is out-of-date.
                  Try another URL(webcal://www.google.com/calendar/ical/spielplan.1.bundesliga%40gmail.com/public/basic.ics) or yours.
                    daniellang
                    @sean said in Problem with MMM-CalendarEXT:
                    THANK YOU…it worked… now i have do work at the google calender… thx Sean!!
                      chrixbrown
                      I have the problem with this module but accessing the mirror gives me an error, how can I fix it?
                        DJBOOB66
                        Need to know what error??
