    Cannot find module "moment"
    98 Posts 2 Posters 51.9k Views 2 Watching
    • U Offline
      uok825 @sdetweil
      @sdetweil https://github.com/AdamMoses-GitHub/MMM-TwitterTrendsByPlace
      But i cant install that
        sdetweil @uok825
        @uok825 well, its because he did a bad thing, and didn’t document that he needed the ‘twitter’ library module
        (there is no package.json file to document the module dependencies)
        but his node_helper.js says require(‘twitter’);
        go to the module folder and do
        npm install twitter
        U 1 Reply Last reply Reply Quote 0
        • U Offline
          uok825 @sdetweil
          @sdetweil Yeah i know. When i tried to npm install twitter. The electron has been failed cause i think the Pi zero stuff. Then its failed, i tried npm uninstall twitter. And the problem started.
            sdetweil @uok825
            @uok825 there is no electron for pi 0… if u install with my script, I setup server mode and then launch chromium over the server… (doing npm start , starts my run-start.sh script)
            U 2 Replies Last reply Reply Quote 0
            • U Offline
              uok825 @sdetweil
              @sdetweil I installed with your script. Its been working for a 1,5 years. Now its broken what can i do?
              • U Offline
                uok825 @sdetweil
                @sdetweil Anything you can help me?
                  sdetweil @uok825
                  @uok825 well… try
                  from the MagicMirror folder
                  rm package-lock.json
                  rm -rf node_modules
                  npm install
                  • U Offline
                    uok825 @sdetweil
                    @sdetweil I used your script, it wouldn’t be a problem, right?
                      sdetweil @uok825
                      @uok825 u mean to install, or upgrade?
                      • U Offline
                        uok825 @sdetweil
                        @sdetweil Both. My upgrade.log
                        Upgrade started - Paz Tem 12 22:41:23 +03 2020
                        system is Linux raspberrypi 4.19.118+ #1311 Mon Apr 27 14:16:15 BST 2020 armv6l GNU/Linux
                        the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                        user requested to apply changes
                        doing test run = false
                        saving custom.css
                        remote name = origin
                        upgrading from version 2.11.0 to 2.12.0
                        fetching latest revisions
                        git fetch rc=0
                        current branch = master
                        On branch master
                        Your branch is up to date with 'origin/master'.
                          (use "git add <file>..." to update what will be committed)
                          (use "git checkout -- <file>..." to discard changes in working directory)
                        	modified:   installers/mm.sh
                        	modified:   modules/default/newsfeed/newsfeed.js
                        	modified:   package-lock.json
                        	modified:   package.json
                        Untracked files:
                          (use "git add <file>..." to include in what will be committed)
                        	core
                        	css/icons/
                        	css/save_custom.css
                        	fonts/LemonMilk.otf
                        	installers/pm2_MagicMirror.json
                        	run-start.sh
                        no changes added to commit (use "git add" and/or "git commit -a")
                        there are 4 local files that are different than the master repo
                           installers/mm.sh
                           package-lock.json
                           package.json
                        save/restore files selection = n
                        restoring installers/mm.sh from repo
                        restoring modules/default/newsfeed/newsfeed.js from repo
                        restoring package-lock.json from repo
                        restoring package.json from repo
                        test merge result rc='' , if empty, no conflicts
                        executing merge, apply specified
                        merge result rc= 0
                         Already up to date.
                        processor architecture is armv6l
                        > magicmirror@2.12.0 install /home/pi/MagicMirror
                        " && cd vendor && npm install --loglevel=error
                        audited 150 packages in 44.188s
                        found 8 vulnerabilities (7 low, 1 high)
                          run `npm audit fix` to fix them, or `npm audit` for details
                        > magicmirror@2.12.0 postinstall /home/pi/MagicMirror
                        > npm run install-fonts && echo "MagicMirror installation finished successfully!
                        > magicmirror@2.12.0 install-fonts /home/pi/MagicMirror
                        > echo "Installing fonts ...
                        " && cd fonts && npm install --loglevel=error
                        updated 1 package and audited 1 package in 19.099s
                        found 0 vulnerabilities
                        audited 1050 packages in 275.039s
                        74 packages are looking for funding
                          run `npm fund` for details
                        found 62 vulnerabilities (61 low, 1 moderate)
                        npm install completed - Paz Tem 12 22:46:48 +03 2020 on base
                        package.json update for armv6l completed ok
                        downloading dumpactivemodules script
                        processing for module MMM-MyPrayerTimes please wait
                        npm notice created a lockfile as package-lock.json. You should commit this file.
                        added 2 packages from 6 contributors and audited 2 packages in 12.29s
                        processing complete for module MMM-MyPrayerTimes
                        processing for module MMM-PIR please wait
                        > epoll@2.0.10 install /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
                        > node-gyp rebuild
                        make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
                          CXX(target) Release/obj.target/epoll/src/epoll.o
                          SOLINK_MODULE(target) Release/obj.target/epoll.node
                          COPY Release/epoll.node
                        make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
                        added 6 packages from 9 contributors and audited 6 packages in 57.611s
                        processing complete for module MMM-PIR
                        restoring custom.css
                        removing git alias
                        Upgrade ended - Paz Tem 12 22:48:25 +03 2020
                        Upgrade started - Sal Tem 14 17:31:45 +03 2020
                        saving custom.css
                        local version 2.12.0 already same as master 2.12.0
                        removing git alias
                        Upgrade ended - Sal Tem 14 17:31:48 +03 2020
                        Upgrade started - Cum Eki 30 11:24:00 +03 2020
                        saving custom.css
                        restoring file    package.json before switch back to master branch
                        package-lock.json: needs merge
                        local version 2.13.0 already same as master 2.13.0
                        removing git alias
                        Upgrade ended - Cum Eki 30 11:24:05 +03 2020
                        • 10
                        • 1 / 10
