    Cannot find module "moment"
    98 Posts 2 Posters 67.0k Views 2 Watching
    • U
      uok825
      After i want to try install twitter(npm) it crashed btw. Then i can’t access my localhost. I use PI Zero W .Here is my logs:
        sdetweil @uok825
        @uok825 that is calendar having trouble… how did u install MM?
        that should have been loaded when npm install was done
        2.16 is the current version… 2.13 is 9 months ago
        U 1 Reply Last reply Reply Quote 0
        • U
          uok825 @sdetweil
          @sdetweil i tryed to unistall twitter. May be thats the cause. Sorry for bad English. I ran your update script.
            sdetweil @uok825
            @uok825 update is AFTER u have been running, and a new release comes out…
            it takes two steps…
            1 1st run is a test run to tell you what might be issues… maybe u need to save some files, or something…
            or u made changes to module files and forgot u did that
            2 rerun with a parameter to actually DO the update
            if u don’t do 2, then you didn’t update
            twitter should have no effect
            which twitter module?
            • U
              uok825 @sdetweil
              @sdetweil https://github.com/AdamMoses-GitHub/MMM-TwitterTrendsByPlace
              But i cant install that
                sdetweil @uok825
                @uok825 well, its because he did a bad thing, and didn’t document that he needed the ‘twitter’ library module
                (there is no package.json file to document the module dependencies)
                but his node_helper.js says require(‘twitter’);
                go to the module folder and do
                npm install twitter
                • U
                  uok825 @sdetweil
                  @sdetweil Yeah i know. When i tried to npm install twitter. The electron has been failed cause i think the Pi zero stuff. Then its failed, i tried npm uninstall twitter. And the problem started.
                    sdetweil @uok825
                    @uok825 there is no electron for pi 0… if u install with my script, I setup server mode and then launch chromium over the server… (doing npm start , starts my run-start.sh script)
                    U 2 Replies Last reply Reply Quote 0
                    • U
                      uok825 @sdetweil
                      @sdetweil I installed with your script. Its been working for a 1,5 years. Now its broken what can i do?
                      • U
                        uok825 @sdetweil
                        @sdetweil Anything you can help me?
                          sdetweil @uok825
                          @uok825 well… try
                          from the MagicMirror folder
                          rm package-lock.json
                          rm -rf node_modules
                          npm install
                          • U
                            uok825 @sdetweil
                            @sdetweil I used your script, it wouldn’t be a problem, right?
                              sdetweil @uok825
                              @uok825 u mean to install, or upgrade?
                              • U
                                uok825 @sdetweil
                                @sdetweil Both. My upgrade.log
                                Upgrade started - Paz Tem 12 22:41:23 +03 2020
                                system is Linux raspberrypi 4.19.118+ #1311 Mon Apr 27 14:16:15 BST 2020 armv6l GNU/Linux
                                the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                                user requested to apply changes
                                doing test run = false
                                saving custom.css
                                remote name = origin
                                upgrading from version 2.11.0 to 2.12.0
                                fetching latest revisions
                                git fetch rc=0
                                current branch = master
                                On branch master
                                Your branch is up to date with 'origin/master'.
                                  (use "git add <file>..." to update what will be committed)
                                  (use "git checkout -- <file>..." to discard changes in working directory)
                                	modified:   installers/mm.sh
                                	modified:   modules/default/newsfeed/newsfeed.js
                                	modified:   package-lock.json
                                	modified:   package.json
                                Untracked files:
                                  (use "git add <file>..." to include in what will be committed)
                                	core
                                	css/icons/
                                	css/save_custom.css
                                	fonts/LemonMilk.otf
                                	installers/pm2_MagicMirror.json
                                	run-start.sh
                                no changes added to commit (use "git add" and/or "git commit -a")
                                there are 4 local files that are different than the master repo
                                   installers/mm.sh
                                   package-lock.json
                                   package.json
                                save/restore files selection = n
                                restoring installers/mm.sh from repo
                                restoring modules/default/newsfeed/newsfeed.js from repo
                                restoring package-lock.json from repo
                                restoring package.json from repo
                                test merge result rc='' , if empty, no conflicts
                                executing merge, apply specified
                                merge result rc= 0
                                 Already up to date.
                                processor architecture is armv6l
                                > magicmirror@2.12.0 install /home/pi/MagicMirror
                                " && cd vendor && npm install --loglevel=error
                                audited 150 packages in 44.188s
                                found 8 vulnerabilities (7 low, 1 high)
                                  run `npm audit fix` to fix them, or `npm audit` for details
                                > magicmirror@2.12.0 postinstall /home/pi/MagicMirror
                                > npm run install-fonts && echo "MagicMirror installation finished successfully!
                                > magicmirror@2.12.0 install-fonts /home/pi/MagicMirror
                                > echo "Installing fonts ...
                                " && cd fonts && npm install --loglevel=error
                                updated 1 package and audited 1 package in 19.099s
                                found 0 vulnerabilities
                                audited 1050 packages in 275.039s
                                74 packages are looking for funding
                                  run `npm fund` for details
                                found 62 vulnerabilities (61 low, 1 moderate)
                                npm install completed - Paz Tem 12 22:46:48 +03 2020 on base
                                package.json update for armv6l completed ok
                                downloading dumpactivemodules script
                                processing for module MMM-MyPrayerTimes please wait
                                npm notice created a lockfile as package-lock.json. You should commit this file.
                                added 2 packages from 6 contributors and audited 2 packages in 12.29s
                                processing complete for module MMM-MyPrayerTimes
                                processing for module MMM-PIR please wait
                                > epoll@2.0.10 install /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
                                > node-gyp rebuild
                                make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
                                  CXX(target) Release/obj.target/epoll/src/epoll.o
                                  SOLINK_MODULE(target) Release/obj.target/epoll.node
                                  COPY Release/epoll.node
                                make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
                                added 6 packages from 9 contributors and audited 6 packages in 57.611s
                                processing complete for module MMM-PIR
                                restoring custom.css
                                removing git alias
                                Upgrade ended - Paz Tem 12 22:48:25 +03 2020
                                Upgrade started - Sal Tem 14 17:31:45 +03 2020
                                saving custom.css
                                local version 2.12.0 already same as master 2.12.0
                                removing git alias
                                Upgrade ended - Sal Tem 14 17:31:48 +03 2020
                                Upgrade started - Cum Eki 30 11:24:00 +03 2020
                                saving custom.css
                                restoring file    package.json before switch back to master branch
                                package-lock.json: needs merge
                                local version 2.13.0 already same as master 2.13.0
                                removing git alias
                                Upgrade ended - Cum Eki 30 11:24:05 +03 2020
                                  sdetweil @uok825
                                  @uok825 those are from 2020
                                  • U
                                    uok825 @sdetweil
                                    @sdetweil I haven’t upgraded since 2020. Now when I run your script, nothing happens?
                                      sdetweil @uok825
                                      @uok825 cut and paste the whole line from the github page, right
                                      • U
                                        uok825 @sdetweil
                                        @sdetweil Yeah.
                                          sdetweil @uok825
                                          @uok825 hm, that means the curl to get the script is failing
                                          • U
                                            uok825 @sdetweil
                                            @sdetweil I can get a new file called upgrade-script.sh and paste all code in it? Thats will work i think?
                                            • 1 / 5
