    Cannot find module "moment"
    98 Posts 2 Posters 64.8k Views 2 Watching
    • U Offline
      uok825 @sdetweil
      @sdetweil Yeah i know. When i tried to npm install twitter. The electron has been failed cause i think the Pi zero stuff. Then its failed, i tried npm uninstall twitter. And the problem started.
        sdetweil @uok825
        @uok825 there is no electron for pi 0… if u install with my script, I setup server mode and then launch chromium over the server… (doing npm start , starts my run-start.sh script)
        U 2 Replies Last reply Reply Quote 0
        • U Offline
          uok825 @sdetweil
          @sdetweil I installed with your script. Its been working for a 1,5 years. Now its broken what can i do?
          • U Offline
            uok825 @sdetweil
            @sdetweil Anything you can help me?
              sdetweil @uok825
              @uok825 well… try
              from the MagicMirror folder
              rm package-lock.json
              rm -rf node_modules
              npm install
              U 1 Reply Last reply Reply Quote 0
              • U Offline
                uok825 @sdetweil
                @sdetweil I used your script, it wouldn’t be a problem, right?
                  sdetweil @uok825
                  @uok825 u mean to install, or upgrade?
                  • U Offline
                    uok825 @sdetweil
                    @sdetweil Both. My upgrade.log
                    Upgrade started - Paz Tem 12 22:41:23 +03 2020
                    system is Linux raspberrypi 4.19.118+ #1311 Mon Apr 27 14:16:15 BST 2020 armv6l GNU/Linux
                    the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                    user requested to apply changes
                    doing test run = false
                    saving custom.css
                    remote name = origin
                    upgrading from version 2.11.0 to 2.12.0
                    fetching latest revisions
                    git fetch rc=0
                    current branch = master
                    On branch master
                    Your branch is up to date with 'origin/master'.
                      (use "git add <file>..." to update what will be committed)
                      (use "git checkout -- <file>..." to discard changes in working directory)
                    	modified:   installers/mm.sh
                    	modified:   modules/default/newsfeed/newsfeed.js
                    	modified:   package-lock.json
                    	modified:   package.json
                    Untracked files:
                      (use "git add <file>..." to include in what will be committed)
                    	core
                    	css/icons/
                    	css/save_custom.css
                    	fonts/LemonMilk.otf
                    	installers/pm2_MagicMirror.json
                    	run-start.sh
                    no changes added to commit (use "git add" and/or "git commit -a")
                    there are 4 local files that are different than the master repo
                       installers/mm.sh
                       package-lock.json
                       package.json
                    save/restore files selection = n
                    restoring installers/mm.sh from repo
                    restoring modules/default/newsfeed/newsfeed.js from repo
                    restoring package-lock.json from repo
                    restoring package.json from repo
                    test merge result rc='' , if empty, no conflicts
                    executing merge, apply specified
                    merge result rc= 0
                     Already up to date.
                    processor architecture is armv6l
                    > magicmirror@2.12.0 install /home/pi/MagicMirror
                    " && cd vendor && npm install --loglevel=error
                    audited 150 packages in 44.188s
                    found 8 vulnerabilities (7 low, 1 high)
                      run `npm audit fix` to fix them, or `npm audit` for details
                    > magicmirror@2.12.0 postinstall /home/pi/MagicMirror
                    > npm run install-fonts && echo "MagicMirror installation finished successfully!
                    > magicmirror@2.12.0 install-fonts /home/pi/MagicMirror
                    > echo "Installing fonts ...
                    " && cd fonts && npm install --loglevel=error
                    updated 1 package and audited 1 package in 19.099s
                    found 0 vulnerabilities
                    audited 1050 packages in 275.039s
                    74 packages are looking for funding
                      run `npm fund` for details
                    found 62 vulnerabilities (61 low, 1 moderate)
                    npm install completed - Paz Tem 12 22:46:48 +03 2020 on base
                    package.json update for armv6l completed ok
                    downloading dumpactivemodules script
                    processing for module MMM-MyPrayerTimes please wait
                    npm notice created a lockfile as package-lock.json. You should commit this file.
                    added 2 packages from 6 contributors and audited 2 packages in 12.29s
                    processing complete for module MMM-MyPrayerTimes
                    processing for module MMM-PIR please wait
                    > epoll@2.0.10 install /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
                    > node-gyp rebuild
                    make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
                      CXX(target) Release/obj.target/epoll/src/epoll.o
                      SOLINK_MODULE(target) Release/obj.target/epoll.node
                      COPY Release/epoll.node
                    make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
                    added 6 packages from 9 contributors and audited 6 packages in 57.611s
                    processing complete for module MMM-PIR
                    restoring custom.css
                    removing git alias
                    Upgrade ended - Paz Tem 12 22:48:25 +03 2020
                    Upgrade started - Sal Tem 14 17:31:45 +03 2020
                    saving custom.css
                    local version 2.12.0 already same as master 2.12.0
                    removing git alias
                    Upgrade ended - Sal Tem 14 17:31:48 +03 2020
                    Upgrade started - Cum Eki 30 11:24:00 +03 2020
                    saving custom.css
                    restoring file    package.json before switch back to master branch
                    package-lock.json: needs merge
                    local version 2.13.0 already same as master 2.13.0
                    removing git alias
                    Upgrade ended - Cum Eki 30 11:24:05 +03 2020
                      sdetweil @uok825
                      @uok825 those are from 2020
                      • U Offline
                        uok825 @sdetweil
                        @sdetweil I haven’t upgraded since 2020. Now when I run your script, nothing happens?
                          sdetweil @uok825
                          @uok825 cut and paste the whole line from the github page, right
                          • U Offline
                            uok825 @sdetweil
                            @sdetweil Yeah.
                              sdetweil @uok825
                              @uok825 hm, that means the curl to get the script is failing
                              • U Offline
                                uok825 @sdetweil
                                @sdetweil I can get a new file called upgrade-script.sh and paste all code in it? Thats will work i think?
                                  sdetweil @uok825
                                  @uok825 yes should
                                  i am in the car for another half an hour
                                  • U Offline
                                    uok825 @sdetweil
                                    @sdetweil Okey. I will do ./upgrade-script.sh right?
                                      sdetweil @uok825
                                      @uok825 yes, and with apply as parm
                                      • U Offline
                                        uok825 @sdetweil
                                        @sdetweil said in Cannot find module "moment":
                                        pi@raspberrypi:~/MagicMirror $ bash upgrade-script.sh apply
                                        No LSB modules are available.
                                        saving custom.css
                                        reverting to master branch from develop, saving changed files
                                        saving file package.json as package.json.save before switch back to master branch
                                        error: you need to resolve your current index first
                                        unable to change back to master branch, stopping execution
                                          sdetweil @uok825
                                          @uok825 said in Cannot find module "moment":
                                          looks like some attempt to merge failed
                                          run this in the MagicMirror folder
                                          git diff --name-only --diff-filter=U
                                          • U Offline
                                            uok825 @sdetweil
                                            pi@raspberrypi:~/MagicMirror $ git diff --name-only --diff-filter=U
                                            package-lock.json
                                            • 1 / 5
