    Cannot find module "moment"
    98 Posts 2 Posters 68.3k Views 2 Watching
      sdetweil @uok825
      @uok825 yes should
      i am in the car for another half an hour
      U 1 Reply Last reply
      • U
        uok825 @sdetweil
        @sdetweil Okey. I will do ./upgrade-script.sh right?
          sdetweil @uok825
          @uok825 yes, and with apply as parm
          • U
            uok825 @sdetweil
            @sdetweil said in Cannot find module "moment":
            pi@raspberrypi:~/MagicMirror $ bash upgrade-script.sh apply
            No LSB modules are available.
            doing test run = false
            saving custom.css
            reverting to master branch from develop, saving changed files
            saving file package.json as package.json.save before switch back to master branch
            restoring file package.json before switch back to master branch
            error: you need to resolve your current index first
            unable to change back to master branch, stopping execution
              sdetweil @uok825
              @uok825 said in Cannot find module "moment":
              looks like some attempt to merge failed
              run this in the MagicMirror folder
              git diff --name-only --diff-filter=U
              • U
                uok825 @sdetweil
                pi@raspberrypi:~/MagicMirror $ git diff --name-only --diff-filter=U
                package-lock.json
                  sdetweil @uok825
                  @uok825 that’s weird. that file is rebuilt every install
                  rm package-lock.json
                  then
                  git status
                  and git branch
                  also, connect via ssh, then everything will be in text so you can just copy/paste
                  • U
                    uok825 @sdetweil
                    @sdetweil rm: ‘package-lock.json’ cant deleted: No such a file or folder.
                      sdetweil @uok825
                      @uok825 ok, still weird
                      do git checkout master
                      • U
                        uok825 @sdetweil
                        git checkout master
                          sdetweil @uok825
                          @uok825 ok try these two commands
                          <file> is package-lock.json
                          this restores the file status in the index
                          git reset – <file>
                          then check out a copy from the index
                          git checkout – <file>
                          notice that is two dashes
                          U 2 Replies Last reply
                          • U
                            uok825 @sdetweil
                            @sdetweil I’ll do ’ git reset - package-lock-json ’ right?
                              sdetweil @uok825
                              @uok825 and then git checkout …
                              and then git status
                              • U
                                uok825 @sdetweil
                                @sdetweil Sorry. I dont understand Sam. Can you help a little. What exactly will I write?
                                  sdetweil @uok825
                                  @uok825 there are two commands
                                  git reset -- package-lock.json
                                  and
                                  git checkout -- package-lock.json
                                  then git status
                                  • U
                                    uok825 @sdetweil
                                      sdetweil @uok825
                                      @uok825 ok, now,
                                      git checkout master
                                      • U
                                        uok825 @sdetweil
                                        @uok825 ok, now,
                                        git checkout master
                                          sdetweil @uok825
                                          @uok825 ok, the upgrade script will handle that
                                          run upgrade with apply
                                          • U
                                            uok825 @sdetweil
                                            @sdetweil Nothing Happened.
                                            My Log again:
                                            Upgrade started - Paz Tem 12 22:41:23 +03 2020
                                            system is Linux raspberrypi 4.19.118+ #1311 Mon Apr 27 14:16:15 BST 2020 armv6l GNU/Linux
                                            the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                                            user requested to apply changes
                                            saving custom.css
                                            remote name = origin
                                            upgrading from version 2.11.0 to 2.12.0
                                            fetching latest revisions
                                            git fetch rc=0
                                            current branch = master
                                            On branch master
                                            Your branch is up to date with 'origin/master'.
                                              (use "git add <file>..." to update what will be committed)
                                              (use "git checkout -- <file>..." to discard changes in working directory)
                                            	modified:   installers/mm.sh
                                            	modified:   modules/default/newsfeed/newsfeed.js
                                            	modified:   package-lock.json
                                            	modified:   package.json
                                            Untracked files:
                                              (use "git add <file>..." to include in what will be committed)
                                            	core
                                            	css/icons/
                                            	css/save_custom.css
                                            	fonts/LemonMilk.otf
                                            	installers/pm2_MagicMirror.json
                                            	run-start.sh
                                            no changes added to commit (use "git add" and/or "git commit -a")
                                            there are 4 local files that are different than the master repo
                                               installers/mm.sh
                                               package-lock.json
                                               package.json
                                            save/restore files selection = n
                                            restoring installers/mm.sh from repo
                                            restoring modules/default/newsfeed/newsfeed.js from repo
                                            restoring package-lock.json from repo
                                            restoring package.json from repo
                                            test merge result rc='' , if empty, no conflicts
                                            executing merge, apply specified
                                            merge result rc= 0
                                             Already up to date.
                                            processor architecture is armv6l
                                            > magicmirror@2.12.0 install /home/pi/MagicMirror
                                            " && cd vendor && npm install --loglevel=error
                                            audited 150 packages in 44.188s
                                            found 8 vulnerabilities (7 low, 1 high)
                                              run `npm audit fix` to fix them, or `npm audit` for details
                                            > magicmirror@2.12.0 postinstall /home/pi/MagicMirror
                                            > npm run install-fonts && echo "MagicMirror installation finished successfully!
                                            > magicmirror@2.12.0 install-fonts /home/pi/MagicMirror
                                            > echo "Installing fonts ...
                                            " && cd fonts && npm install --loglevel=error
                                            updated 1 package and audited 1 package in 19.099s
                                            found 0 vulnerabilities
                                            audited 1050 packages in 275.039s
                                            74 packages are looking for funding
                                              run `npm fund` for details
                                            found 62 vulnerabilities (61 low, 1 moderate)
                                            npm install completed - Paz Tem 12 22:46:48 +03 2020 on base
                                            package.json update for armv6l completed ok
                                            downloading dumpactivemodules script
                                            processing for module MMM-MyPrayerTimes please wait
                                            npm notice created a lockfile as package-lock.json. You should commit this file.
                                            added 2 packages from 6 contributors and audited 2 packages in 12.29s
                                            processing complete for module MMM-MyPrayerTimes
                                            processing for module MMM-PIR please wait
                                            > epoll@2.0.10 install /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
                                            > node-gyp rebuild
                                            make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
                                              CXX(target) Release/obj.target/epoll/src/epoll.o
                                              SOLINK_MODULE(target) Release/obj.target/epoll.node
                                              COPY Release/epoll.node
                                            make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
                                            added 6 packages from 9 contributors and audited 6 packages in 57.611s
                                            processing complete for module MMM-PIR
                                            restoring custom.css
                                            removing git alias
                                            Upgrade ended - Paz Tem 12 22:48:25 +03 2020
                                            Upgrade started - Sal Tem 14 17:31:45 +03 2020
                                            saving custom.css
                                            local version 2.12.0 already same as master 2.12.0
                                            removing git alias
                                            Upgrade ended - Sal Tem 14 17:31:48 +03 2020
                                            Upgrade started - Cum Eki 30 11:24:00 +03 2020
                                            saving custom.css
                                            package-lock.json: needs merge
                                            local version 2.13.0 already same as master 2.13.0
                                            removing git alias
                                            Upgrade ended - Cum Eki 30 11:24:05 +03 2020
                                            Upgrade started - Paz Tem 18 13:21:20 +03 2021
                                            saving custom.css
                                            would restore file package.json before switch back to master branch
                                            Upgrade ended - Paz Tem 18 13:21:23 +03 2021
                                            Upgrade started - Paz Tem 18 13:44:35 +03 2021
                                            saving custom.css
                                            Upgrade ended - Paz Tem 18 13:44:37 +03 2021
                                            Upgrade started - Paz Tem 18 13:44:39 +03 2021
                                            saving custom.css
                                            Upgrade ended - Paz Tem 18 13:44:41 +03 2021
                                            Raspberry’s date is wrong
                                            • 2 / 5
