    Cannot find module "moment"
    98 Posts 2 Posters 64.4k Views 2 Watching
    • U Offline
      uok825 @sdetweil
      @sdetweil said in Cannot find module "moment":
      git checkout master
        sdetweil @uok825
        @uok825 ok try these two commands
        <file> is package-lock.json
        this restores the file status in the index
        git reset – <file>
        then check out a copy from the index
        git checkout – <file>
        notice that is two dashes
        U 2 Replies Last reply Reply Quote 0
        • U Offline
          uok825 @sdetweil
          @sdetweil I’ll do ’ git reset - package-lock-json ’ right?
            sdetweil @uok825
            @uok825 and then git checkout …
            and then git status
            • U Offline
              uok825 @sdetweil
              @sdetweil Sorry. I dont understand Sam. Can you help a little. What exactly will I write?
                sdetweil @uok825
                @uok825 there are two commands
                git reset -- package-lock.json
                and
                git checkout -- package-lock.json
                then git status
                U 1 Reply Last reply Reply Quote 0
                • U Offline
                  uok825 @sdetweil
                    sdetweil @uok825
                    @uok825 ok, now,
                    git checkout master
                    • U Offline
                      uok825 @sdetweil
                      @uok825 ok, now,
                      git checkout master
                        sdetweil @uok825
                        @uok825 ok, the upgrade script will handle that
                        run upgrade with apply
                        • U Offline
                          uok825 @sdetweil
                          @sdetweil Nothing Happened.
                          My Log again:
                          Upgrade started - Paz Tem 12 22:41:23 +03 2020
                          system is Linux raspberrypi 4.19.118+ #1311 Mon Apr 27 14:16:15 BST 2020 armv6l GNU/Linux
                          the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                          user requested to apply changes
                          doing test run = false
                          saving custom.css
                          remote name = origin
                          upgrading from version 2.11.0 to 2.12.0
                          fetching latest revisions
                          git fetch rc=0
                          current branch = master
                          On branch master
                          Your branch is up to date with 'origin/master'.
                            (use "git add <file>..." to update what will be committed)
                            (use "git checkout -- <file>..." to discard changes in working directory)
                          	modified:   installers/mm.sh
                          	modified:   modules/default/newsfeed/newsfeed.js
                          	modified:   package-lock.json
                          	modified:   package.json
                          Untracked files:
                            (use "git add <file>..." to include in what will be committed)
                          	core
                          	css/icons/
                          	css/save_custom.css
                          	fonts/LemonMilk.otf
                          	installers/pm2_MagicMirror.json
                          	run-start.sh
                          no changes added to commit (use "git add" and/or "git commit -a")
                          there are 4 local files that are different than the master repo
                             installers/mm.sh
                             package-lock.json
                             package.json
                          save/restore files selection = n
                          restoring installers/mm.sh from repo
                          restoring modules/default/newsfeed/newsfeed.js from repo
                          restoring package-lock.json from repo
                          restoring package.json from repo
                          test merge result rc='' , if empty, no conflicts
                          executing merge, apply specified
                          merge result rc= 0
                           Already up to date.
                          processor architecture is armv6l
                          > magicmirror@2.12.0 install /home/pi/MagicMirror
                          " && cd vendor && npm install --loglevel=error
                          audited 150 packages in 44.188s
                          found 8 vulnerabilities (7 low, 1 high)
                            run `npm audit fix` to fix them, or `npm audit` for details
                          > magicmirror@2.12.0 postinstall /home/pi/MagicMirror
                          > npm run install-fonts && echo "MagicMirror installation finished successfully!
                          > magicmirror@2.12.0 install-fonts /home/pi/MagicMirror
                          > echo "Installing fonts ...
                          " && cd fonts && npm install --loglevel=error
                          updated 1 package and audited 1 package in 19.099s
                          found 0 vulnerabilities
                          audited 1050 packages in 275.039s
                          74 packages are looking for funding
                            run `npm fund` for details
                          found 62 vulnerabilities (61 low, 1 moderate)
                          npm install completed - Paz Tem 12 22:46:48 +03 2020 on base
                          package.json update for armv6l completed ok
                          downloading dumpactivemodules script
                          processing for module MMM-MyPrayerTimes please wait
                          npm notice created a lockfile as package-lock.json. You should commit this file.
                          added 2 packages from 6 contributors and audited 2 packages in 12.29s
                          processing complete for module MMM-MyPrayerTimes
                          processing for module MMM-PIR please wait
                          > epoll@2.0.10 install /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
                          > node-gyp rebuild
                          make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
                            CXX(target) Release/obj.target/epoll/src/epoll.o
                            SOLINK_MODULE(target) Release/obj.target/epoll.node
                            COPY Release/epoll.node
                          make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
                          added 6 packages from 9 contributors and audited 6 packages in 57.611s
                          processing complete for module MMM-PIR
                          restoring custom.css
                          removing git alias
                          Upgrade ended - Paz Tem 12 22:48:25 +03 2020
                          Upgrade started - Sal Tem 14 17:31:45 +03 2020
                          saving custom.css
                          local version 2.12.0 already same as master 2.12.0
                          removing git alias
                          Upgrade ended - Sal Tem 14 17:31:48 +03 2020
                          Upgrade started - Cum Eki 30 11:24:00 +03 2020
                          saving custom.css
                          restoring file    package.json before switch back to master branch
                          package-lock.json: needs merge
                          local version 2.13.0 already same as master 2.13.0
                          removing git alias
                          Upgrade ended - Cum Eki 30 11:24:05 +03 2020
                          Upgrade started - Paz Tem 18 13:21:20 +03 2021
                          saving custom.css
                          reverting to master branch from develop, saving changed files
                          would restore file package.json before switch back to master branch
                          Upgrade ended - Paz Tem 18 13:21:23 +03 2021
                          Upgrade started - Paz Tem 18 13:44:35 +03 2021
                          saving custom.css
                          Upgrade ended - Paz Tem 18 13:44:37 +03 2021
                          Upgrade started - Paz Tem 18 13:44:39 +03 2021
                          saving custom.css
                          saving file package.json as package.json.save before switch back to master branch
                          Upgrade ended - Paz Tem 18 13:44:41 +03 2021
                          Raspberry’s date is wrong
                            sdetweil @uok825
                            @uok825 ok, I don’t get it.
                            git status
                            again
                            • U Offline
                              uok825 @sdetweil
                              git status
                                sdetweil @uok825
                                @uok825 ok
                                git checkout package.json
                                git checkout master
                                • U Offline
                                  uok825 @sdetweil
                                  git checkout master
                                    sdetweil @uok825
                                    @uok825 but we just checked out the older copy, so it should be unchanged now…
                                    git diff package.json
                                    • U Offline
                                      uok825 @sdetweil
                                        sdetweil @uok825
                                        @uok825 right, says no changes…
                                        grep start package.json
                                        • U Offline
                                          uok825 @sdetweil
                                          Can you give me a Reputation. I cant reply you fast.
                                            sdetweil @uok825
                                            @uok825 hm… but that’s different than master, shouldn’t be.
                                            git stash
                                            git checkout master
                                            • 2 / 5
