    Cannot find module "moment"
    98 Posts 2 Posters 67.0k Views 2 Watching
    • U
      uok825 @sdetweil
      @sdetweil Okey. I will do ./upgrade-script.sh right?
        sdetweil @uok825
        @uok825 yes, and with apply as parm
        U 1 Reply Last reply Reply Quote 0
        • U
          uok825 @sdetweil
          @sdetweil said in Cannot find module "moment":
          pi@raspberrypi:~/MagicMirror $ bash upgrade-script.sh apply
          No LSB modules are available.
          doing test run = false
          saving custom.css
          reverting to master branch from develop, saving changed files
          saving file package.json as package.json.save before switch back to master branch
          restoring file package.json before switch back to master branch
          error: you need to resolve your current index first
          unable to change back to master branch, stopping execution
            sdetweil @uok825
            @uok825 said in Cannot find module "moment":
            looks like some attempt to merge failed
            run this in the MagicMirror folder
            git diff --name-only --diff-filter=U
            • U
              uok825 @sdetweil
              pi@raspberrypi:~/MagicMirror $ git diff --name-only --diff-filter=U
              package-lock.json
                sdetweil @uok825
                @uok825 that’s weird. that file is rebuilt every install
                rm package-lock.json
                then
                git status
                and git branch
                also, connect via ssh, then everything will be in text so you can just copy/paste
                • U
                  uok825 @sdetweil
                  @sdetweil rm: ‘package-lock.json’ cant deleted: No such a file or folder.
                    sdetweil @uok825
                    @uok825 ok, still weird
                    do git checkout master
                    • U
                      uok825 @sdetweil
                      git checkout master
                        sdetweil @uok825
                        @uok825 ok try these two commands
                        <file> is package-lock.json
                        this restores the file status in the index
                        git reset – <file>
                        then check out a copy from the index
                        git checkout – <file>
                        notice that is two dashes
                        U 2 Replies Last reply Reply Quote 0
                        • U
                          uok825 @sdetweil
                          @sdetweil I’ll do ’ git reset - package-lock-json ’ right?
                            sdetweil @uok825
                            @uok825 and then git checkout …
                            and then git status
                            • U
                              uok825 @sdetweil
                              @sdetweil Sorry. I dont understand Sam. Can you help a little. What exactly will I write?
                                sdetweil @uok825
                                @uok825 there are two commands
                                git reset -- package-lock.json
                                and
                                git checkout -- package-lock.json
                                then git status
                                • U
                                  uok825 @sdetweil
                                    sdetweil @uok825
                                    @uok825 ok, now,
                                    git checkout master
                                    • U
                                      uok825 @sdetweil
                                      @uok825 ok, now,
                                      git checkout master
                                        sdetweil @uok825
                                        @uok825 ok, the upgrade script will handle that
                                        run upgrade with apply
                                        • U
                                          uok825 @sdetweil
                                          @sdetweil Nothing Happened.
                                          My Log again:
                                          Upgrade started - Paz Tem 12 22:41:23 +03 2020
                                          system is Linux raspberrypi 4.19.118+ #1311 Mon Apr 27 14:16:15 BST 2020 armv6l GNU/Linux
                                          the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                                          user requested to apply changes
                                          saving custom.css
                                          remote name = origin
                                          upgrading from version 2.11.0 to 2.12.0
                                          fetching latest revisions
                                          git fetch rc=0
                                          current branch = master
                                          On branch master
                                          Your branch is up to date with 'origin/master'.
                                            (use "git add <file>..." to update what will be committed)
                                            (use "git checkout -- <file>..." to discard changes in working directory)
                                          	modified:   installers/mm.sh
                                          	modified:   modules/default/newsfeed/newsfeed.js
                                          	modified:   package-lock.json
                                          	modified:   package.json
                                          Untracked files:
                                            (use "git add <file>..." to include in what will be committed)
                                          	core
                                          	css/icons/
                                          	css/save_custom.css
                                          	fonts/LemonMilk.otf
                                          	installers/pm2_MagicMirror.json
                                          	run-start.sh
                                          no changes added to commit (use "git add" and/or "git commit -a")
                                          there are 4 local files that are different than the master repo
                                             installers/mm.sh
                                             package-lock.json
                                             package.json
                                          save/restore files selection = n
                                          restoring installers/mm.sh from repo
                                          restoring modules/default/newsfeed/newsfeed.js from repo
                                          restoring package-lock.json from repo
                                          restoring package.json from repo
                                          test merge result rc='' , if empty, no conflicts
                                          executing merge, apply specified
                                          merge result rc= 0
                                           Already up to date.
                                          processor architecture is armv6l
                                          > magicmirror@2.12.0 install /home/pi/MagicMirror
                                          " && cd vendor && npm install --loglevel=error
                                          audited 150 packages in 44.188s
                                          found 8 vulnerabilities (7 low, 1 high)
                                            run `npm audit fix` to fix them, or `npm audit` for details
                                          > magicmirror@2.12.0 postinstall /home/pi/MagicMirror
                                          > npm run install-fonts && echo "MagicMirror installation finished successfully!
                                          > magicmirror@2.12.0 install-fonts /home/pi/MagicMirror
                                          > echo "Installing fonts ...
                                          " && cd fonts && npm install --loglevel=error
                                          updated 1 package and audited 1 package in 19.099s
                                          found 0 vulnerabilities
                                          audited 1050 packages in 275.039s
                                          74 packages are looking for funding
                                            run `npm fund` for details
                                          found 62 vulnerabilities (61 low, 1 moderate)
                                          npm install completed - Paz Tem 12 22:46:48 +03 2020 on base
                                          package.json update for armv6l completed ok
                                          downloading dumpactivemodules script
                                          processing for module MMM-MyPrayerTimes please wait
                                          npm notice created a lockfile as package-lock.json. You should commit this file.
                                          added 2 packages from 6 contributors and audited 2 packages in 12.29s
                                          processing complete for module MMM-MyPrayerTimes
                                          processing for module MMM-PIR please wait
                                          > epoll@2.0.10 install /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
                                          > node-gyp rebuild
                                          make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
                                            CXX(target) Release/obj.target/epoll/src/epoll.o
                                            SOLINK_MODULE(target) Release/obj.target/epoll.node
                                            COPY Release/epoll.node
                                          make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
                                          added 6 packages from 9 contributors and audited 6 packages in 57.611s
                                          processing complete for module MMM-PIR
                                          restoring custom.css
                                          removing git alias
                                          Upgrade ended - Paz Tem 12 22:48:25 +03 2020
                                          Upgrade started - Sal Tem 14 17:31:45 +03 2020
                                          saving custom.css
                                          local version 2.12.0 already same as master 2.12.0
                                          removing git alias
                                          Upgrade ended - Sal Tem 14 17:31:48 +03 2020
                                          Upgrade started - Cum Eki 30 11:24:00 +03 2020
                                          saving custom.css
                                          package-lock.json: needs merge
                                          local version 2.13.0 already same as master 2.13.0
                                          removing git alias
                                          Upgrade ended - Cum Eki 30 11:24:05 +03 2020
                                          Upgrade started - Paz Tem 18 13:21:20 +03 2021
                                          saving custom.css
                                          would restore file package.json before switch back to master branch
                                          Upgrade ended - Paz Tem 18 13:21:23 +03 2021
                                          Upgrade started - Paz Tem 18 13:44:35 +03 2021
                                          saving custom.css
                                          Upgrade ended - Paz Tem 18 13:44:37 +03 2021
                                          Upgrade started - Paz Tem 18 13:44:39 +03 2021
                                          saving custom.css
                                          Upgrade ended - Paz Tem 18 13:44:41 +03 2021
                                          Raspberry’s date is wrong
                                            sdetweil @uok825
                                            @uok825 ok, I don’t get it.
                                            git status
                                            again
                                            • 2 / 5
