    Cannot find module "moment"
    98 Posts 2 Posters 68.6k Views 2 Watching
      sdetweil @uok825
      @uok825 those are from 2020
      U 1 Reply Last reply
      • U
        uok825 @sdetweil
        @sdetweil I haven’t upgraded since 2020. Now when I run your script, nothing happens?
          sdetweil @uok825
          @uok825 cut and paste the whole line from the github page, right
          • U
            uok825 @sdetweil
            @sdetweil Yeah.
              sdetweil @uok825
              @uok825 hm, that means the curl to get the script is failing
              • U
                uok825 @sdetweil
                @sdetweil I can get a new file called upgrade-script.sh and paste all code in it? Thats will work i think?
                  sdetweil @uok825
                  @uok825 yes should
                  i am in the car for another half an hour
                  • U
                    uok825 @sdetweil
                    @sdetweil Okey. I will do ./upgrade-script.sh right?
                      sdetweil @uok825
                      @uok825 yes, and with apply as parm
                      • U
                        uok825 @sdetweil
                        @sdetweil said in Cannot find module "moment":
                        pi@raspberrypi:~/MagicMirror $ bash upgrade-script.sh apply
                        No LSB modules are available.
                        doing test run = false
                        saving custom.css
                        reverting to master branch from develop, saving changed files
                        saving file package.json as package.json.save before switch back to master branch
                        restoring file package.json before switch back to master branch
                        error: you need to resolve your current index first
                        unable to change back to master branch, stopping execution
                          sdetweil @uok825
                          @uok825 said in Cannot find module "moment":
                          looks like some attempt to merge failed
                          run this in the MagicMirror folder
                          git diff --name-only --diff-filter=U
                          • U
                            uok825 @sdetweil
                            pi@raspberrypi:~/MagicMirror $ git diff --name-only --diff-filter=U
                            package-lock.json
                              sdetweil @uok825
                              @uok825 that’s weird. that file is rebuilt every install
                              rm package-lock.json
                              then
                              git status
                              and git branch
                              also, connect via ssh, then everything will be in text so you can just copy/paste
                              • U
                                uok825 @sdetweil
                                @sdetweil rm: ‘package-lock.json’ cant deleted: No such a file or folder.
                                  sdetweil @uok825
                                  @uok825 ok, still weird
                                  do git checkout master
                                  • U
                                    uok825 @sdetweil
                                    git checkout master
                                      sdetweil @uok825
                                      @uok825 ok try these two commands
                                      <file> is package-lock.json
                                      this restores the file status in the index
                                      git reset – <file>
                                      then check out a copy from the index
                                      git checkout – <file>
                                      notice that is two dashes
                                      U 2 Replies Last reply
                                      • U
                                        uok825 @sdetweil
                                        @sdetweil I’ll do ’ git reset - package-lock-json ’ right?
                                          sdetweil @uok825
                                          @uok825 and then git checkout …
                                          and then git status
                                          • U
                                            uok825 @sdetweil
                                            @sdetweil Sorry. I dont understand Sam. Can you help a little. What exactly will I write?
                                            • 2 / 5
