    Weather.gov forecast status in Weather module
    3 Posts 2 Posters 1.9k Views 2 Watching
    • ankonaskiff17A Offline
      ankonaskiff17
      Just wondering what the status of the default Weather module is in regards to FORECAST when using provider weather.gov
      I’m using it twice, once for current and once for forecast.
      A while back I messed with this module and struggled with forecast but today forecast doing its thing, admittedly with a shot in the dark tweak I used off of the National Weather Service website where they talk about the API.
      ankonaskiff17A 1 Reply Last reply Reply Quote 0
        ankonaskiff17 @ankonaskiff17
        @sdetweil Just wanted to pass on that have two iterations of the default weather module running. One for “current” and one for forecast using weathergov as my data source. Appears I can do away with weatherEndpoint on both with no ill effects.
        There is a NWS API Page that runs through an example. Follow example using the appropriate gps coordinates for your location. In my screen capture you see /gridpoints/CAE/70,67/forecast/hourly which relates to my local NWS radar at CAE which is local airport. I do not think this will work for people trying to get finer resolution via someone’s weather station who is uploading their data to a 3rd party provider.
        I have seen the CURRENT forecast drop out infrequently but it has always come back on its own.
        Daily forecast.
        Current Forecast
        MagicMirror Output
        ankonaskiff17A 1 Reply Last reply Reply Quote 2
          @sdetweil I added some text and link to API page to better describe and locate the NWS API example. People should be better able to understand how to make that work.
