PushBulletNotifications Module issues?
@achilles debug is so you might be able to analyze the debug info to determine the problem
note that you have to open the developers window console tab to see the debug infodo you see the header?
@sdetweil Ah, I see. I am not familiar with the developers window, so I am looking into that now.
@sdetweil I think I was able to look at the developers window tab. I see two errors:
“Failed to load resource…server responded with a status of 404 (Not Found)”
“Error on loading script:…PushBulletNotifications//MMM-PushbulletNotifications.js”
@achilles said in PushBulletNotifications Module issues?:
the filename must match the folder name which must match the name inside the filename and must match the module name
exact case.
above the filename has a lowercase b , but the folder has uppercase
@sdetweil Thanks, but of course, I have complicated the issue now. I discovered that I needed to upgrade my MagicMirror. Of course, now that I have done that, it is not displaying at all. I am looking at a previous thread about this in which you helped someone else with that issue and trying to fix this.
Thanks again…I could be posting another thread on working through that issue! Ha.
